Configuration of the Cisco ISR 4431/K9 in front of Cisco ASA 5515-X Active/Stand-by cluster
RetroGrade11
Hi Cisco Community,
We currently have HP MSR 50-40 router sitting in front of our Cisco ASA 5515-X Active/Standby cluster that has ISP internet connection coming in from the ISP switch, which then distributes this connection to active ASA node and standby ASA node for redundancy.
The topology looks like this:
Internet -> ISP switch -> HP MSR Internet Router -> Cisco ASA firewall cluster -> HP core switch (LAN)
 We have recently purchased Cisco ISR 4431/K9 router to replace HP MSR 50-40 with it. However, here is the issue I’m running into. The current HP MSR 50-40 router interfaces are configured with “port link-mode bridge” command, which in effect renders them as layer 2 switch interfaces. In order for me to use the same setup, I would have to obtain a switch module for the ISR to be able to access switchport command on the ISR, as it’s currently not available. While researching the workaround, I came across something called “service-instance” and “bridge-domain” that may allow me to create group of interfaces on the ISR to act as Layer 2 in order to achieve similar goal.
Does anyone know if using service-instance with bridge-domain is a feasible approach? I’m providing a sample of my ISR config below. If this is a valid approach, do you think the config below will work?
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
subscriber templating
redundancy
 mode none
vlan internal allocation policy ascending
ip tftp source-interface GigabitEthernet0
ip ssh source-interface GigabitEthernet0
bridge irb
interface GigabitEthernet0/0/0
 description To ISP Switch
 no ip address
 negotiation auto
 no mop enabled
 service instance 1 ethernet
  encapsulation default
  bridge-domain 1
interface GigabitEthernet0/0/1
 description To ASA1
 no ip address
 negotiation auto
 no mop enabled
  bridge-domain 1
interface GigabitEthernet0/0/2
 description To ASA2
 no ip address
 negotiation auto
 no mop enabled
  bridge-domain 1
 description GE0 to Core
 vrf forwarding Mgmt-intf
 ip address 10.x.x.x 255.255.255.0
 negotiation auto
 no mop enabled
interface Vlan1
 no ip address
 no mop enabled
interface BDI1
 ip address 12.x.x.x 255.x.x.x
router ospf 711
 network 10.x.x.x 0.0.0.0 area 0.0.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.x.x.x
ip ospf name-lookup
access-list 100 permit ip any any
bridge 1 protocol dec
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
end
0 Replies 0
