10-19-2013 05:27 AM - edited 03-04-2019 09:21 PM
Hello Everybody
I´m a new fan of the PFR technologie, i´m some difficultie for set the learning mode.
Here is the scenario,
i have one 2 routers connecting to 4 ISP, each border router have 2 ISP or 2 External link
So my goal is to set a kind of load sharing for some application,
I need for example for my Http traffic to be performed based on the best External link
So i have this configuration on my PFR Master, but i´m not able to looking the Sh pfr master, the learn list doesn´t match anything
pfr master
logging
border 3.3.3.3 key-chain PFRVICTORIA
interface FastEthernet0/1.212 external
interface FastEthernet0/0 internal
interface Tunnel10 external
border 10.30.21.1 key-chain PFRVICTORIA
interface FastEthernet0/1.210 external
interface FastEthernet0/1.211 external
ip access-list extended Defined_PFR_Appl
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq smtp
learn
throughput
delay
periodic-interval 0
monitor-period 1
list seq 10 refname myApply
traffic-class access-list Defined_PFR_App
throughput
sh pfr master
RT-EDGE-INTERNET2#sh pfr master
OER state: ENABLED and ACTIVE
Conn Status: SUCCESS, PORT: 3949
Version: 3.0
Number of Border routers: 2
Number of Exits: 4
Number of monitored prefixes: 345 (max 5000)
Max prefixes: total 5000 learn 2500
Prefix count: total 345, learn 345, cfg 0
PBR Requirements met
Nbar Status: Inactive
Border Status UP/DOWN AuthFail Version
3.3.3.3 ACTIVE UP 00:38:50 0 3.0
10.30.21.1 ACTIVE UP 00:38:52 0 3.0
Global Settings:
max-range-utilization percent 20 recv 0
mode route metric bgp local-pref 5000
mode route metric static tag 5000
trace probe delay 1000
logging
exit holddown time 60 secs, time remaining 0
Default Policy Settings:
backoff 300 3000 300
delay relative 50
holddown 300
periodic 0
probe frequency 56
number of jitter probe packets 100
mode route observe
mode monitor both
mode select-exit good
loss relative 10
jitter threshold 20
mos threshold 3.60 percent 30
unreachable relative 50
resolve delay priority 11 variance 20
resolve range priority 12 variance 0
resolve utilization priority 13 variance 20
Learn Settings:
current state : STARTED
time remaining in current state : 74 seconds
throughput
delay
no inside bgp
monitor-period 1
periodic-interval 0
aggregation-type prefix-length 24
prefixes 100 appls 100
expire after time 720
Learn-List seq 10 refname myApply
Configuration:
Traffic-Class Access-list: Defined_PFR_App
Aggregation-type: prefix-length 24
Learn type: throughput
Session count: 1000 Max count: 1000
Status: INACTIVE
Stats:
Traffic-Class Count: 0
10-20-2013 07:26 AM
Hi Junior,
An access-list under a pfr learn list is used to define the application signature rather than filtering . Applications can be identified either using port, protocol, dscp or any combination of it.we use the ACL to match the type of traffic and a prefix-list to match the destination prefix.
Refer : http://aitaseller.wordpress.com/2012/10/15/pfr-cisco-performance-routing/
Sathvik
