Configuration Professional
Gregor Bizjak
I have Cisco 892 (CISCO892-K9) with trial version of IOS content filtering, which I would like to manage through Configuration Professional 2.5. The Express version works fine while CP version doesn't start. It stops when "Retrieving Port".
I changed some settings at Java menu, I also use DHCP server with 10.10.10.0/24 address range, I'm connected to port FE0 like it's said at Getting Started PDF and I use Win 7 with latest Java.
Could anyone help me?
cadet alain
Maybe this can help you : http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_professional/guides/CiscoCPqsg.html#wp135354
Regards.
Alain.
Found the solution thanx to "cadet alain" -> I just needed to read details - you need to "run as administrator", and then CP opens sucessfully.
Thank you for your post! It helped me!
Just some keywords for guys who got into the same trouble:
Cisco 800 series Retrieving Port issue resolved
Cisco 891 Retrieving Port problem resolved
Cisco 892 Retrieving Port stuck resolved
Thanks this helped!
