Configuration required to create IP Sec VPN Tunnel
saurabh.bansal
Hi Team,
We want to configure IP Sec VPN tunnel between central site and few of remote sites in our n/w.We are using EIGRP protocol in our network for connecting central site & all remote sites.Is any special configuration needs to be done to create IP Sec VPN tunnel by using EIGRP or else we can create tunnel with the common IP Sec configuration.
Jon Marshall
Saurabh
If you want to pass EIGRP routing updates between your sites over the IPSEC tunnels then you will need to use GRE with IPSEC -
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html#anchor8
Jon
