BGP Configuration Help
cozyk1515
Here is the customers L3 Switch - What am I missing here? Let me know if more info is needed.
interface GigabitEthernet0/3
ip address Other Provider IP B.B.B.170 255.255.255.252 secondary
duplex auto
speed auto
media-type rj45
negotiation auto
router bgp ##AS##
no synchronization
bgp log-neighbor-changes
network x.x.x.x
neighbor B.B.B.169 remote-as ##B's AS##
neighbor B.B.B.169 description Primelink
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 B.B.B.169
ip route 0.0.0.0 255.255.255.255 10.1.1.0
no ip http server
no ip http secure-server
ip as-path access-list 1 permit ^##B'sAS##$
logging alarm informational
access-list 10 permit X.X.X.X 0.0.255.255
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 101 permit ip any any
route-map AS-B'sAS-INCOMING permit 10
match as-path 1
route-map AS-B'sAS-OUTGOING permit 10
match ip address 10
route-map AS-15320-OUTGOING permit 20
match ip address 20
Jerry Ye
Hi Gabrielle,
Any special reason you make the interface IP address secondary? Also, what are you trying to accomplish with this static route?
I don't see your as-path access-list and route-map applied inside the BGP process.
jerry
I am trying to help this customer get this up and running. I have another static that was for testing on the interface that is why it is secondary. Also, I am not sure why he has this route of 10.1.1.0.
Hi Gabrielle,
You might have problem with the BGP peering section since the BGP peering will use the primary IP address. Beside that, this is the only issue I am seeing so far.
HTH,
jerry
