Configure AAA via RADIUS server on Cisco ISR4331 in PT
DrByte
In Packet Tracer I want to configure Cisco ISR4331 router to use RADIUS authentication for vty lines and console..
Maybe it is limitations of Packet Tracer or limitations of my understanding AAA topic, but can it be configured completely without any local credentials.., I mean no local users, no local or enable secrets/passwords?
And additionally I would want to configure it the way that, You don't have to type username and password twice - I mean on login, and on `enable` command.
So far I tried:
Building configuration...
Current configuration : 1661 bytes
version 16.6.4
no service timestamps debug datetime msec
hostname R4
no logging console
aaa new-model
aaa authentication login default group radius
aaa authentication enable default group radius
aaa authorization exec default group radius
aaa authorization network default group radius
no ip cef
no ipv6 cef
no ip domain-lookup
ip domain-name network.co.il
spanning-tree mode pvst
interface GigabitEthernet0/0/0
 no ip address
 ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 ciscoOSPF
 duplex auto
 speed auto
interface GigabitEthernet0/0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/0/2
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/1/0
 ip address 10.100.4.1 255.255.255.0
interface Serial0/1/1
 ip address 10.100.1.2 255.255.255.0
interface Vlan1
 no ip address
 shutdown
router ospf 1
 log-adjacency-changes
 passive-interface GigabitEthernet0/0/0
 network 10.100.1.0 0.0.0.255 area 0
 network 10.100.4.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
radius server RADIUS-SRV
 address ipv4 172.18.1.1 auth-port 1645
 key radsecret
radius server 172.18.1.1
 key radsecret
logging 172.18.1.1
line con 0
line aux 0
line vty 0 4
 login authentication default
 transport input ssh
end
It works fine:
- I can connect via ssh with username:password
- It requires username:password on console line
- No local usernames and password configured
[!] However it does require to type twice username and password - once for login
and second time for entering privileged EXEC mode.
How can I disable this double typing? Thanks in advance!
pieterh
radius server login1
 address ipv4 <ip-addr> auth-port 1812 acct-port 1813
 key <n> <radius-pre-shared-key>
aaa group server radius login-servers
 server name login1
 ! or multiple servers
aaa authentication login SSH group login-servers local enable
     ! if you omit the "local" keyword, there is no fallback to local authentication
line vty 0 4
 authorization exec SSH
 login authentication SSH
in a real environment, you way want to keep some fallback option for when the radius-server is unreachable
you can reserve local authentication for only physical console access
aaa authentication login CONSOLE local enable
line con 0
    exec-timeout 30 0
   authorization exec CONSOLE
   login authentication CONSOLE
