Configure access control and zone-based firewall
an_ho
Hi everyone,
I am still working on getting my cisco router (C1111X-8P, ip base and sec licenses) up and working. I have managed to configure DHCP and NAT for my clients, but I am having trouble setting up firewall and access control.
Interface configuration:
G0/0/0 -> ISP
G0/1/0-7 -> LAN
For the firewall, I want all traffic from the clients in the LAN to be passed through/inspected by the firewall (including return traffic), but unsolicited traffic from the internet arriving at g0/0/0 should be dropped.
In addition, no router services should be accessible from the internet/g0/0/0.
Can anyone help me on how to configure this?
Thanks a lot!
add the lines marked in bold:
version 17.6
ip name-server 8.8.8.8 8.8.4.4
ip domain name localdomain.local
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
lease 7
login on-success log
subscriber templating
vlan internal allocation policy ascending
class-map type inspect match-any IN-TO-OUT
match access-group name IN-TO-OUT_acl
match protocol http
match protocol ftp
match protocol icmp
match protocol https
match protocol dns
match protocol smtp
match protocol pop3
match protocol tcp
match protocol udp
policy-map type inspect OUTSIDE-TO-SELF-POLICY
class class-default
drop log
policy-map type inspect INSIDE-OUTSIDE-POLICY
class type inspect IN-TO-OUT
inspect
class class-default
drop log
zone security INSIDE
description Zone for inside interfaces
zone security OUTSIDE
description Zone for outside interfaces
zone-pair security INSIDE-OUTSIDE source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-OUTSIDE-POLICY
zone-pair security OUTSIDE-TO-SELF source OUTSIDE destination self
service-policy type inspect OUTSIDE-TO-SELF-POLICY
interface GigabitEthernet0/0/0
ip dhcp client client-id ascii XXXX
ip address dhcp
ip nbar protocol-discovery
ip nat outside
zone-member security OUTSIDE
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
zone-member security INSIDE
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
ip nat inside
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip forward-protocol nd
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
ip access-list standard 1
11 permit 192.168.1.0 0.0.0.255
12 Replies 12
are you trying to configure a zone based firewall ? Post the configuration you have so far, so we can fill in the bits and pieces...
here is a sample config of the zone based firewall, configured to achieve what you are requiring:
version 17.3
hostname ISR1111
boot-start-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
license udi pid CISCO1921/K9 sn FTX1520037Y
username admin privilege 15 password 0 cisco
description ISP_INTERNET
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description LAN
ip nat inside
duplex auto
speed auto
class-map type inspect match-all INSIDE-TO-OUTSIDE-CLASS
match protocol http
match protocol ftp
match protocol dns
match protocol udp
match protocol tcp
match protocol pop3
match protocol smtp
match protocol icmp
policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
class type inspect INSIDE-TO-OUTSIDE-CLASS
inspect
class class-default
drop log
zone-pair security IN-TO-OUT source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-TO-OUTSIDE-POLICY
access-list 1 permit 192.168.1.0 0.0.0.255
ip http server
ip http access-class 23
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Thanks for your help. Please see below for the relevant parts of my configuration:
version 17.6
service config
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname CiscoRouter
boot-start-marker
boot system bootflash:c1100-universalk9.17.06.01a.SPA.bin
boot system bootflash:c1100-universalk9.17.05.01a.SPA.bin
boot-end-marker
no aaa new-model
clock timezone GMT 1 0
ip nbar http-services
ip dhcp pool LAN
lease 7
diagnostic bootup level minimal
username admin privilege 15 password 0 default
redundancy
mode none
class-map type inspect match-all IN-TO-OUT
class-map type inspect match-all OUT-TO-IN
match access-group name OUT-TO-IN_acl
inspect
class class-default
drop log
policy-map type inspect OUTSIDE-INSIDE-POLICY
class type inspect OUT-TO-IN
inspect
class class-default
drop log
zone security default
zone-pair security OUTSIDE-INSIDE source OUTSIDE destination INSIDE
service-policy type inspect OUTSIDE-INSIDE-POLICY
ip dhcp client client-id ascii FGXXXXXXX
ip address dhcp
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip http server
ip dns server
ip access-list extended IN-TO-OUT_acl
10 permit ip any any
ip access-list extended OUT-TO-IN_acl
Do I really need the ip access-list standard 1? Will the server be reachable via HTTP(s) on the OUTSIDE interface?
Thanks!
with your current configuration, all traffic inbound from the Internet is allowed, is this what you want ?
Access list 1 is necessary for NAT.
No, I would change the OUT-TO-IN to "drop" as default action, but would that not drop any return traffic from request originating on the inside?
Even after changing this to "drop" I can still access the web interface on the outside interface...how can I deny this access?
Thanks for your help, greatly appreciated!
if you just want to deny all traffic from the outside, just delete all the outside config marked in bold:
version 17.6
service config
service call-home
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
lease 7
redundancy
mode none
--> no class-map type inspect match-all OUT-TO-IN
inspect
class class-default
drop log
--> no policy-map type inspect OUTSIDE-INSIDE-POLICY
inspect
class class-default
drop log
--> no zone-pair security OUTSIDE-INSIDE source OUTSIDE destination INSIDE
ip address dhcp
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
ip nat inside
ip http server
ip dns server
--> no ip access-list extended OUT-TO-IN_acl
Thanks for the help and sorry for the late reply! I have deleted the access-lists above, but I am still able to access the web interface on the outside interface...
Additionally, on the web interface, there are not ACLs configured for g0/0/0 - does the firewall config supersede the individual ACLs or do I need to add this to the interface?
make the changes marked in bold:
version 17.6
service config
service call-home
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
lease 7
redundancy
mode none
match protocol http
match protocol ftp
match protocol icmp
match protocol dns
match protocol smtp
match protocol pop3
match protocol tcp
match protocol udp
inspect
class class-default
drop
ip address dhcp
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
ip nat inside
ip http server
ip dns server
Thanks - see below for the show run output. Some lines have been added by the WebGUI. Unfortunately, I am still able to connect to the webinterface and ssh on the external interface (which, since this is facing the internet, is not a good idea). Any ideas what I am doing wrong?
version 17.6
ip dhcp pool LAN
lease 7
match protocol http
match protocol ftp
match protocol icmp
match protocol dns
match protocol smtp
match protocol pop3
match protocol tcp
match protocol udp
inspect
class class-default
drop log
ip address dhcp
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
ip nat inside
ip http server
ip dns server
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
version 17.6
ip dhcp pool LAN
lease 7
match protocol http
match protocol ftp
match protocol icmp
match protocol dns
match protocol smtp
match protocol pop3
match protocol tcp
match protocol udp
class class-default
drop log
inspect
class class-default
drop log
ip address dhcp
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
ip nat inside
ip http server
ip dns server
Thanks! That helped, but encountered some strange behaviour of the router. For instance, when I add the commands above from the CLI (via ssh), the new policies are not displayed when accessing the router via WebUI. So I reverted back to the previous configuration and tried to configure everything via webui. The layout of my network is as follows:
|ISP|---(DHCP)----|Router|---(DHCP)---|Clients|
On the router, interface g0/0/0 (and later possibly g0/0/1, once I get fiber) are the external interfaces. They need to be able to acquire an IP via DHCP (as the ISP is handing them out this way), but every unsolicited traffic should be blocked. In particular, traffic to the webui or the ssh port should be blocked.
The router is acting as a DHCP server for the clients, who should be able to access the internet (using any protocol), but any unsolicited traffic originating on the outside/internet should be dropped at the router.
I have managed to restrict access to the webui/ssh on the external interfaces, but despite my configuration, dhcp seems also to be blocked and the router does not acquire an IP from the ISP. Please see below for my config:
version 17.6
ip dhcp pool LAN
lease 7
class-map type inspect match-any DHCP_app
match protocol udp
match protocol http
match protocol ftp
match protocol icmp
match protocol dns
match protocol smtp
match protocol pop3
match protocol tcp
match protocol udp
class-map type inspect match-all Drop_but_DHCP
match access-group name Drop_but_DHCP_acl
class-map match-any DHCP_nbar_app
match protocol dhcp
class-map type inspect match-all DHCP
match class-map DHCP_app
match access-group name DHCP_acl
policy-map type inspect avc DHCP_app_policy
class DHCP_nbar_app
allow
class class-default
allow
policy-map type inspect OUTSIDE-SELF-POLICY
class type inspect DHCP
inspect
service-policy avc DHCP_app_policy
class type inspect Drop_but_DHCP
drop
class class-default
drop log
inspect
class class-default
drop log
zone-pair security OUTSIDE-SELF source OUTSIDE destination self
service-policy type inspect OUTSIDE-SELF-POLICY
ip address dhcp
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
ip nat inside
ip http server
ip dns server
ip access-list extended DHCP_acl
ip access-list extended Drop_but_DHCP_acl
Hello
Although ZBFW would be the most viable option, A more simplistic approach as you only are using two interfaces could be to use CBAC with unicast ueverse path porwarding (uRPF)
Example:
ip access-list extended 100
remark allow dhcp
permit udp any any eq bootpc
deny ip any any
ip inspect name CBAC tcp
ip inspect name CBAC udp
ip inspect name CBAC icmp
int x/x
descritipn wan facing
ip access-group100  in
ip inspect CBAC out
ip verify unicast source reachable-via rx allow-default 100
Kind Regards
Paul
