internet connection goes down for couple of seconds and coming up
amralrazzaz
Level 5
Level 5
internet keep going down and up many times
my connection ( isp--asa--router--sw-sw--users)
im facing an issue happen randomly maybe periodically that internet connection goes down for
couple of seconds and coming up again , and this effecting our calls and meeting virtually
i have checked with ISP and no issue from there side
so i need help to get an ideas why internet connection packet losses for seconds and coming back?
is it power of network devices or cables between trunk ports or what ...
any idea of the internfaces that i can check the drop packets
i have received from ISP that i have to configure ip tcp adjust-mss 1300 under interface
and this configured on int which facing the switched
is this maybe the reason ? and shall i configure this also on ASA inside int which connected o this
router ? or shall i configure this command also to the int of router facing the asa ?)
also for the AP ( wap300n dlink ) can i check the dropped packet on this interface which connected
to switch? maybe issue from this ?
dont know
on router :
interface GigabitEthernet0/0
description connected to local NW-INTERVLAN
no ip address
ip flow ingress
ip flow egress
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description connected to ASA
ip address -----------------
ip access-group BLOCK_SSH in
ip flow ingress
ip flow egress
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
AP INTERFACE :
C2960X-EGCAI01-SW2#show interfaces gigabitEthernet 1/0/14
GigabitEthernet1/0/14 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 5Z7c.6ZZ5.ZZZ (5Z7c.6ZZ5.ZZZ)
Description: connected_AP_Campina_Office
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 6/255, rxload 4/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1312
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1898000 bits/sec, 408 packets/sec
5 minute output rate 2374000 bits/sec, 463 packets/sec
57359046 packets input, 33349832377 bytes, 0 no buffer
Received 2285994 broadcasts (2007312 multicasts)
0 watchdog, 2007312 multicast, 0 pause input
89029935 packets output, 71188877663 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
amr alrazzaz
36 Replies 36
balaji.bandi
May be worth Run some EEM Script to run on ASA to confirm your Internet Link working as expected, before you get in to your network issue.
step 1.
ASA to Internet working, when you see the issue in the  Lan network ?
Step2 : (this should not cause the issue, but worth checking)
Step3 : what users effecting all users, only Wifi ? ( connect device directly to ASA and see if that works when you have issue ?)
BB
Dear how to run EEM Script on ASA for testing the internet stability ?
shall i connect one device directly to asa with public ip address and check the connectivity ? and how to test this ? is it on the asa interface where connected to this device
also regarding this command line : ip tcp adjust-mss 1300 its recommended from ISP  "? where shall i put exactly on which interfaces ? and maybe this can cause the issue ? i dnt know ?
regarding drop packet on interface which connected to AP ? who can i check ? what can cause this ? specially there are no load of users in office ? ( im using channel width 40 MHZ Only with wireless band 5 ghz)
amr alrazzaz
here is the example :
https://www.cisco.com/c/en/us/support/docs/security/adaptive-security-appliance-asa-software/117883-config-eem-00.html
-- Sure to identify the problem connect some dedicated node to ASA, runing some ping plotter to collect the information.
-if the FW connected directly to provider then you need to run that in ASA example :
https://www.cisco.com/c/en/us/td/docs/security/asa/asa96/configuration/general/asa-96-general-config/interface-mtu.html
- ignore for now, lets test above steps and see if that  improves ?
BB
question please :
for this command ip tcp adjust-mss 1300 ( its already configured on the interface of isp router which facing and connecting to my outside ASA FDM interface and outside asa fdm int is not configured !!) so shall i have to configure same on my asa fdm outside int ? and on inside as well?
i do configured this command only on my local office router interface which facing internal switched which have router on stick sub interfaces for vlans?
how to configure this on ASA FDM ? ( ip tcp adjust-mss 1300)
amr alrazzaz
You confirming that Interface already configured towards ISP side ? - but other question confusing us asking how to configure as below :
also confirm is this ASA Code running or Firepower Code running
if ASA you using ASDM, if the Firepower you use FDM
if ASDM use below :
https://www.cisco.com/c/en/us/td/docs/security/asa/asa97/asdm77/general/asdm-77-general-config/interface-mtu.html#ID-2076-00000095
FDM
https://www.cisco.com/c/en/us/td/docs/security/firepower/630/fdm/fptd-fdm-config-guide-630/fptd-fdm-interfaces.html
BB
I'm using ASA FDM and I'm asking where exactly shall i configured this ( ip tcp adjust-mss 1300) command? on which interfaces ? maybe this could cause the internet connection issue down for couple of seconds and coming back gain?
Network Diagram : ISP  ROUTER ----ASA FDM ----2911 ROUTER ISR ---- SWITCH L2----SWITCH L2 ---- DEVICES&USERS
BTW  this command currently configured on below interfaces only
ISP--------outside int ASAFDM inside int---------(ip tcp adjust-mss 1300) ISR ROUTER  (ip tcp adjust-mss 1300)----- SW1----SW2
also shall i configure this command on each sub interface ? router on stick ? or no need /?
amr alrazzaz
post the full running configs of the ASA, the router, and the two switches...
i have shared the full config already and waiting your kindly reply and recommendations for any modifications so ill follow and apply
Thanks in advance
amr alrazzaz
I might have missed that...where exactly is the output of 'show running-config' of all devices involved ?
Hello @amralrazzaz ,
I would like to suggest you a simpler test to verify if the issue is limited to the WIFI or it impacts also the wired part of your network.
Use two PCs:
PC1 is connected with cable to the internal LAN of your network
PC2 is connected via WIFI
on both PCs you open a Windows OS shell  (cmd)   and use
ping 8.8.8.8 -t
on linux just use ping 8.8.8.8
Examine the results if losses happen only on the WIFI connected PC you may have issues with WIFI re-autentication re-associaiton.
Hope to help
Giuseppe
can you check my wifi setup on ap attached if its fine ?
and for the testing how much time i keep the ping to 8.8.8.8 for both devices ?
regarding the model of this AP it has been using now for almost 6 years maybe 7 years , so if this model is good for business or its recommended to change with advanced one ? and what kind then shall i buy with good price and better performance ? maybe AP performance effecting the signal ???!!
amr alrazzaz
Helllo @amralrazzaz ,
Ideally  the two PCs should be near each other and you give a look at them disable display power off and have the laptop with power connected and disable standby when powered.
Please note that some losses on the WIFI are to be expected so it would be important to have someone looking at the monitors of both PCs to see if there  are losses on both at the same time.
If you stop the tests after hours 4-5 and  compare the results you can understand if the issue is WFI only or it impacts also the wired part of your network,
About your AP configuration I don't see any issue in the configuration.
EDit:
But the picture says it is a Linksys device not D-Link or am I wrong ?
About QoS on WIFI environments you may like to read the following article:
https://mrncciew.com/2021/09/14/rfc-8325-wifi-qos-mappings/
Hope to help
Giuseppe
Hi Larosa,
i have just trying to ping 8.8.8.8 -t from laptop device wired connection only for now about 4-5 hours as u had asked me and the result as below:
Ping statistics for 8.8.8.8:
Packets: Sent = 13685, Received = 13647, Lost = 38 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 85ms, Average = 39ms
and this is output for wifi (around 5 hrs 30 mins ) :
Packets: Sent = 15447, Received = 15388, Lost = 59 (0% loss),
Minimum = 37ms, Maximum = 114ms, Average = 40ms
so it that sounds good ? or ?
amr alrazzaz
David Johnson
Did you check the cable?
