Configure Cisco ASR901 with ATT ADI Fiber
etjen
Hi everyone -
We recently subscribed to ATT ADI fiber (500M) without the managed router from ATT so we can save the monthly cost in the long run.  I recently bought Cisco ASR 901 and hope that I can configure the router on my own.
I am looking for some samples of configuration if someone here has done it before. I have been provided some technical information such as WAN information (CR Serial IP Address, IPv6 CR serial IP Address, Compresses IPv6 Serial IP Address, etc...) and LAN Information (LAN IP Gateway, IPv6 LAN IP Gateway, First Network Assignable, Usable IP Range, etc...).
I only have some basic skills on Cisco router.  Any input will be greatly appreciated.
best to post the current running configuration (sh run) of your ASR. Indicate which interfaces are connected to what (you can put a description on an interface with the 'description' interface command), and we can fill in the rest...
Here is the information from provider:
CR Serial IP Address:32.140.21.114/30
AR Serial IP Address:32.140.24.113/30
WAN IP Address: 32.140.24.112/30
LAN IP Gateway: 12.25.241.193
First Network Assignable:12.25.241.194
Usable IP Range:12.25.241.194 - 12.25.241.222
Broadcast IP Address:12.25.241.223
Subnet Mask:255.255.255.224
Also, when I tried to put ip address on the interface, I got an error stating "IP Address config under this interface is not supported on ASR901"
Here is the running config:
Router#show runn
Building configuration...
Current configuration : 2020 bytes
! Last configuration change at 12:57:43 PST Thu Nov 14 2019 by admin
! NVRAM config last updated at 12:41:17 PST Thu Nov 14 2019
version 15.3
service password-encryption
asr901-platf-multi-nni-cfm
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone PST -8 0
clock calendar-valid
ip cef
no ipv6 cef
l3-over-l2 flush buffers
spanning-tree mode pvst
license boot level AdvancedMetroIPAccess
username admin privilege 15 password 7 06145F754846591E4405425F080C7A2C65
interface GigabitEthernet0/0
no ip address
negotiation auto
interface GigabitEthernet0/1
no ip address
negotiation auto
interface GigabitEthernet0/2
no ip address
negotiation auto
interface GigabitEthernet0/3
no ip address
negotiation auto
interface GigabitEthernet0/4
description WAN
no ip address
negotiation auto
interface GigabitEthernet0/5
description LAN
no ip address
negotiation auto
interface GigabitEthernet0/6
no ip address
negotiation auto
interface GigabitEthernet0/7
no ip address
negotiation auto
interface GigabitEthernet0/8
no ip address
negotiation auto
interface GigabitEthernet0/9
no ip address
negotiation auto
interface GigabitEthernet0/10
no ip address
negotiation auto
interface GigabitEthernet0/11
no ip address
negotiation auto
interface TenGigabitEthernet0/0
no ip address
interface TenGigabitEthernet0/1
no ip address
interface FastEthernet0/0
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
environment monitor
line con 0
login local
line aux 0
transport preferred none
transport output lat pad telnet rlogin udptn ssh
line vty 0 4
login
line vty 5 98
login
exception crashinfo buffersize 128
end
