Configure Double NAT for overlapping remote LAN subnets in VPN tunnel
cybergeek
Hi All
I need some help in configuring the NAT via ASDM, my case is as follows:
I have a requirement where there are multiple subnets with different CIDRs in remote LAN subnets and some of these subnets are already in use by other customers on my end. So i am wondering how we will perform the doublet NAT for these subnets.
e.g. these are the remote LAN subnets i need to configure in the vpn tunnel
10.1.10.0/24
10.1.11.0/24
10.1.12.0/24
10.1.13.0/24
10.1.14.0/24
10.1.15.0/24
10.1.32.0/19
10.1.64.0/18
10.1.128.0/17
Now subnet 10.1.11.0/24, 10.1.12.13, 10.1.32.0/19 are already used by one of my other customers. So i want to know how i will perform the NAT for these overlapping subnet in Cisco ASA. I have picked up some subnets for NAT which are 192.168.60.0/24, 192.168.61.0/24 and 192.168.62.0/24. Also do i need the NAT statement which is automatically generated by ASDM when we choose "NAT exempt" check box. If some can please share the ASDM output how to configure the NAT in this case that will be really helpful.
Thank you very much in Advance.
cybergeek
I am thinking this NAT statement:
nat (Inside,outside) 187 source static 10.1.11.0 192.168.60.0 destination static Customer-Remote-LAN Customer-Remote-LAN
And I will add 192.168.60.0 in Customer-Remote-LAN object group.
