Configure DSL and T1 on 1841
rmrahman0302
I have 1841 router. I have to install T1 and DSL on the router. Also I have 515e firewall. I want to bring few host inside the DMZ. T1 network will be 63.192.183.x network and DSL network will be 66.17.40.x. How can I install DSL and T1 on the router and configure the routing so that both network hosts will be accessible through DMZ.
pradeepde
Level 5
Level 5
The 1800 series router supports the wic-1dsu-t1-v2 and not the wic-1dsu-t1. Here is the link which shows what it supports.
http://www.cisco.com/en/US/products/ps5853/prod_module_install_config_guide09186a00802c47ef.html
So it you want to stick with the 1800 you would need to see about getting the v2 wic.
More information about the config : http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a008009457d.shtml
