Configure dynamic DSL on cisco router 877
Kevin Xau
I have configured a cisco router 877 to run the Dynamic DSL. However, it cannot work, the ATM 0 interface cannot be up . Here is my configuration:
version 12.4
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname cisco-877
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 20
dot11 syslog
no ip source-route
ip cef
no ip domain lookup
username cisco privilege 15 password 7 094F471A1A0A
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/100
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description LAN interface
ip address 172.16.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer1
description DSL interface
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp chap hostname xxxxxx@abc.net
ppp chap password 0 7tmvdvk3khjgk52
ppp pap sent-username xxxxxx@abc.net password 0 7tmvdvk3khjgk52
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
access-list 100 permit ip 172.16.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
Please help me to figure out which part I'm incorrect.
8 Replies 8
lloyd whitton
what interface connent to your LAN? i Notice you configure 1 vlan with ip address 172.16.0.1 255.255.25.0  it look like you need asign it to the LAN interface.
johnlloyd_13
Level 9
Level 9
hi,
could you run some debugs and do a shutdown/no shutdown on the ATM interface?
kindly post debug output.
debug ppp authentication
debug ppp negotiation
Kevin Xau
- To lloyd whitton : The port is L2, only can configure IP on Vlan 1.
- To johnlloyd_13 : I have shut / no shut the ATM interface, and do the debug as you give, but no thing display.
hi,
issue the 'terminal monitor' command if you're connected remotely and redo the debug.
could you also check if you're getting a dial tone on this line?
- I'm using console cable connect directly to the router, but no thing display.
- The line is working fine because before this line connect to the Dlink router, now we want to change to cisco 877 router.
hi,
contact with your telco/service provider if their DSLAM supports this type of router.
I have checked with my ISP SingTel, and they say it can support DSLAM for cisco router 877.
My configuration is missing any command?
hi,
there are some lines i would suggest to be added, but we'll need to make sure your layer 1 is working properly
you sure you've connected the RJ11 to the ADSL/POTS port? please post your 'show interface atm0' output?
if you connect a phone, do you get a dial tone? is there a microfilter in between?
