Configure HWIC-2CE1T1-PRI for Telsta E1 circuit in Australia
IRMAN SETIAWAN
Beginner
Beginner
We are doing hardware refresh for our offices in australia and having issue with bringing up the circuit on the new router.
The old router are all 2621 with WIC-1T and external CSU/DSU. The new router are all 2911 with HWIC-2CE1T1-PRI card.
Please see below for configuration pertaining to the E1 Controller
card type e1 0 0
network-clock-participate wic 0
controller E1 0/0/0
framing NO-CRC4
channel-group 0 timeslots 31
interface Serial0/0/0:0
bandwidth 1984
no ip address
ip flow ingress
encapsulation frame-relay IETF
service-policy output mpls_australia
interface Serial0/0/0:0.1 point-to-point
bandwidth 1984
ip address x.x.x.x 255.255.255.252
ip flow ingress
frame-relay interface-dlci 401 IETF
Here's the circuit information we received from Verizon:
CCS,31 CHANNEL E-1
                       CRC4-OFF,FRAMING FOR E-1
                       HDB3,HIGH DENSITY BIPOLAR 3
                       INTL,INTERNATIONAL
During the cutover, I can see the serial interface is up but line protocol is down, and pvc stayed in deleted state.
Does anyone see anything missing from the controller configurations based on the information that verizon had provided to us ?
Irman
John Blakley
Advisor
Advisor
Irman,
The only thing that I see off the top is the channel-group config. Generally, you list how many channels you have and are including. In the US, we have T1s that have 24 channels. If I'm configuring the controller to use all of them, my channel-group configuration looks like:
channel-group 0 timeslots 1-24
You could try this, but I'm not 100% sure how many channels an E1 has...
If there are 31, you could try:
channel-group 0 timeslots 1-31
HTH,
John
HTH, John *** Please rate all useful posts ***
Recognize Your Peers
