Configure local network on ir829
pmartinez_tst
I just got an IR829 router from cisco. I need to install it inside my local network to test a lorawan module.
It comes with 15.5 ios version. I have tried to follow some tutorials but I don't get it working.
First, I would need a way to remove all the configuration I have could created so far. I execute "setup" some times to see if I could configure network access through this, so I have some interfaces up but without ip, also I have added some dhcp exclusions which I cannot remove with:
no ip dhcp pool NAME
no ip dhcp excluded-address ip...
But it takes no effect when I print the current configuration. I still see the dhcp exclusions right there.
Once this is done, this is my current set up, you tell me if I need to modify something.
I have a local router which creates a local network in ip range: 192.168.10.2-100 255.255.255.0, the router ip is: 192.168.10.1
I have connected a lan port of my router to GE1 of IR829. I don't have the kind of connector of GE0.
I have tried to follow this tutorial:https://communities.cisco.com/docs/DOC-60826 The only step I can't add is: "ip router 0.0.0.0 0.0.0.0 72.163.206.1 ""% Invalid input detected at '^' marker."
Once I run all other commands, I write "exit" to get out of configure mode. Then, if I execute "show iox host list detail", I get 0 host registered.
What should I do to configure this? I need to get internet in this router to download the 15.6 ios version file and update it to allow the use of a lorawan device.
Thank you in advance, I am a bit lost with this device, I haven't used one never.
Palani Mohan
Hi there
Please contact me at pamohan@cisco.com. We need to work together, to review what has been done so far and take it from thereon.
Sincerely ... Palani
