08-03-2021 12:57 AM
Hii, I have recently purchased RV340 Dual Wan Giga router for my office space which I intend to use with the existing 2 ISPs. The problem I am facing is that my primary ISP ( Airtel Xstream Broadband ) let's say ISP1, provides an inbuilt GPON Modem + Router. The WAN option is disabled.
I want to configure it to work as Modem only so that after connecting it to my WAN1 port of RV340, my cisco router is the only device doing the routing work and there are no issues of IP conflict or double-Nat.
08-03-2021 01:28 AM
Hello
Change the connection mode from Router to BRIDGE
08-03-2021 02:09 AM
Hii Paul
Thanks for your reply.
I cannot change the connection mode from route mode to bridge mode in the WAN option since the entire WAN setting is disabled in the ISP1 router, as you can see in the picture of my first post. However, I am getting a check box of ALL ports to Bridge mode under the LAN setting of the router. Should I enable it, will that do the work?? Also, should I disable DHCP? My router also has a DMZ option, does it require any changes?
