08-02-2021 07:05 AM
Based on the BOM below, may i know what is the max. bandwidth that this router can cater? Thank you...
ASR1001-HX= | Cisco ASR1001-HX System,4x10GE+4x1GE,optional crypto+P/S |
CON-PSOP-ARX1001H | PRTNR SUP OS 24X7X4 Cisco ASR1001-HX Sys |
M-ASR1001HX-8GB | Cisco ASR1001-HX 8GB DRAM |
ASR1KX-AC-750W-R | Cisco ASR1000-X 750W AC Power Supply, Reverse Air |
CAB-ACU | AC Power Cord (UK), C13, BS 1363, 2.5m |
L-SLASR1-AES= | Cisco ASR 1000 Advanced Enterprise Services E-Delivery PAK |
CON-PSOP-SLASR1AM | PRTNR SUP OS 24X7X4 Cisco ASR 1000 Advanced Enterprise Ser |
08-02-2021 07:25 AM
i do not see any throughput license : check here :
08-02-2021 07:54 AM - edited 08-02-2021 08:13 AM
Hi Balaji,
is it this is the one?
08-02-2021 08:01 AM - edited 08-02-2021 08:05 AM
This is my complete BOM, please advice if i miss out any SKU. this routers need to support up to throughput 40Gbps (WAN Link Incoming 2x10Gbps). Thanks.
No. | Model | Description | Service Duration | Qty |
ASR1001-HX= | Cisco ASR1001-HX System,4x10GE+4x1GE,optional crypto+P/S | N/A | 2 | |
CON-PSOP-ARX1001H | PRTNR SUP OS 24X7X4 Cisco ASR1001-HX Sys | 24 month(s) | 2 | |
M-ASR1001HX-8GB | Cisco ASR1001-HX 8GB DRAM | N/A | 2 | |
ASR1KX-AC-750W-R | Cisco ASR1000-X 750W AC Power Supply, Reverse Air | N/A | 4 | |
CAB-ACU | AC Power Cord (UK), C13, BS 1363, 2.5m | N/A | 4 | |
L-SLASR1-AES= | Cisco ASR 1000 Advanced Enterprise Services E-Delivery PAK | N/A | 2 | |
CON-PSOP-SLASR1AM | PRTNR SUP OS 24X7X4 Cisco ASR 1000 Advanced Enterprise Ser | 24 month(s) | 2 | |
GLC-TE= | 1000BASE-T SFP transceiver module for Category 5 copper wire | N/A | 4 | |
SFP-10G-SR-X= | 10GBASE-SR SFP Module for Extended Temp range | N/A | 10 | |
GLC-LH-SMD= | 1000BASE-LX/LH SFP transceiver module, MMF/SMF, 1310nm, DOM | N/A | 4 |
08-02-2021 12:54 PM
I could be wrong, but as far as I recall, you only need throughput licenses for encrypted/VPN traffic. The 4x10GE interfaces in your BOM should be all you need to get the throughput desired (40GE), if it is not encrypted traffic obviously...
08-03-2021 02:11 AM
I belive most looks ok, but still you need performance License for Security, please refer the above document mentioned close look.
Note : if you are not sure about the requirement, suggest to contact Local Cisco Partner, if not you end up costing high adding more and more missing component, it may delay delivery and deployment.
we only suggesting based on the input - but still we are not sure what is the requirement.
08-02-2021 02:41 PM
Hello
"The Cisco ASR 1001-HX Router and Cisco ASR 1002-HX Router are a part of the Cisco ASR 1000 Series and offers a compact form factor that consumes less rack space and power while offering 100 Gbps forwarding throughput"
Depending on the overall throughput or encryption performance needed, you can choose among four different modular ESP versions: 20-, 40-, 100-, and 200-Gbps ESPs.
08-02-2021 04:52 PM
@lowhongni wrote:M-ASR1001HX-8GB
This is just the default 8 Gb memory. If this router is going to be facing the internet then do not skimp on the memory, especially the DRAM.
Have a read of this: Cisco ASR 1000 Series Aggregation Services Routers Ordering Guide
