configure nat for interface 0/1
b555555555
i have 2 wans i want configure nat on interface 0/1 and test it with computer connected to 0/1/2(i configured 10.0.0.2 and working dns on the computer interface) my interface address is 192.168.xx.xx 255.255.255.252(configured by internet supplier) and my legal ip address
(by internet supplier) is 213.31.xx.xx subnet 255.255.255.248
i want to give hosts subnet 10.0.0.0
interface 0/0 connected to switch and active i cant touch it
the router is 1841
thanks in advance
b555
interface FastEthernet0/0
description Line To Bez
ip address 10.20.xxx.xxx 255.255.255.252
ip nbar protocol-discovery
speed 100
full-duplex
interface FastEthernet0/1
description Line To Info
ip address 192.168.x.x 255.255.255.252(configured by supplier)
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1/0
description Connected to LAN
interface FastEthernet0/1/1
interface FastEthernet0/1/2
switchport access vlan 3
interface FastEthernet0/1/3
description trunk
switchport mode trunk
shutdown
interface Vlan1
description Line To LAN
ip address 212.179.xxx.xx 255.255.255.248
interface Vlan2
description infonetLegalToLan (not active just for try)
no ip address
interface Vlan3
description infonet
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 10.20.xxx.xxx for first interface
ip route 0.0.0.0 0.0.0.0 192.168.x.x for second interface
no ip http server
ip http authentication local
ip http secure-server
ip nat pool overinfoToUsers 213.31.xx.x 213.31.xx.x netmask 255.255.255.248
ip nat inside source list 7 pool overinfoToUsers overload
ip access-list standard test
access-list 1 permit any
access-list 7 permit 10.0.0.0 0.0.0.255
access-list 18 remark Remote Management
smothuku
Level 7
Level 7
Hi ,
Create an access-list 7 as below
after that go to int f0/0 and configure the command ip nat inside..
access-list 7 permit 10.20.0.0 0.0.0.3.
int f0/0
ip nat inside
Satish.
hi, but i want to nat wan interface 0/1
(wan 0/0 is active now connected to a cheap temporery router thats why i am making tests on interface 0/1 and 10.0.0.0 i want to send the internal computers )
the completed configuration i want 2 valns one for wan 0/0 and for 0/1
thanks in advance
b555
