Configure PPPoE on Router Cisco 2911 with additional IP addresses have been provided by ISP
Referring to the network diagram, ISP providing 5 Public and I've plan to distribute the public IP to Fortigate and Peplink as per network diagram. Therefore, kindly advise the config below is it workable based on the network diagram.
Interface g0/0 -WAN(from ISP)
interface g0/1 -LAN(to switch)
CODE:
hostname IM-R-2911
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 211.27.110.78
ip dhcp pool LINE
network 211.27.110.0 255.255.255.255
default-router 211.27.110.73
dns-server 211.27.110.73
lease 3
ip name-server 1.9.1.9
ip name-server 8.8.8.8
ip cef
no ipv6 cef
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/0.21
encapsulation dot1Q 21
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
ip address 211.27.110.73 255.255.255.255
ip nat inside
duplex auto
speed auto
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1440
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname <xxxx@timebb>
ppp chap password 0 <PWD TIME>
ppp pap sent-username <xxxxx@timebb> password 0 <PWD TIME>
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 10 permit 211.27.110.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
the 211.27.110.x addresses are public IP addresses? If so, you do not have to NAT these addresses. Either assign them statically to your devices, or use DHCP client reservations such as the one below marked in bold/italics.
Also, what subnet mask have you been given for your public addresses ?
For the rest, implement the changes marked in bold:
hostname IM-R-2911
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LINE
--> network 211.27.110.0 255.255.255.0 <-- ?
lease 3
ip dhcp pool FORTIGATE
host 211.27.110.76 255.255.255.0
hardware-address 01f0.def1.9b01.df
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
no ip address
--> no ip nat outside
duplex auto
speed auto
--> ip address 211.27.110.73 255.255.255.0 <-- ?
--> no ip nat inside
duplex auto
speed auto
no cdp enable
interface Dialer1
--> ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
no ip http server
--> no ip nat inside source list 10 interface dialer1 overload
--> no access-list 10 permit 211.27.110.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
transport input all
end
Hello
Yes it probably would however it would be a waste of those routable public addresses.
A more viable way would depend on if you wish for the fortigate and peplink devices to be reachable from the public internet if so then what you can do use private addressing on the internal network for all hosts and then perform NAT on a 1-1 basis with those 5 additional the public addresses against the fortigate and peplink.
Kind Regards
Paul
