Configured router but unable to get internet access?
guitarplyr
                  Hi, I am new to configuring cisco routers and for some reason I am unable to get internet access. All the clients do get an ip address. My config is below, any ideas? Thanks!
Router1#show run
Building configuration...
Current configuration : 6078 bytes
version 15.0
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname Router1
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip dhcp excluded-address 192.168.1.18
ip dhcp excluded-address 192.168.1.1 192.168.1.124
ip dhcp excluded-address 192.168.1.175 192.168.1.254
ip dhcp pool myPool
   network 192.168.1.0 255.255.255.0
   dns-server 192.168.1.22
   default-router 192.168.1.18
   domain-name testdomain
   lease 7
ip domain name testdomain
ip name-server 192.168.1.22
crypto pki trustpoint TP-self-signed-2565028650
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2565028650
revocation-check none
rsakeypair TP-self-signed-2565028650
username admin privilege 15 password 0
interface GigabitEthernet0/0
description inside interface
ip address 192.168.1.18 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description outside interface
ip address 72.54.100.111 255.255.255.252
ip nat outside
no ip route-cache
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat outside source list 100 interface GigabitEthernet0/1
ip route 0.0.0.0 0.0.0.0 72.54.100.111
access-list 3 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password
login
scheduler allocate 20000 1000
ntp update-calendar
ntp server 132.248.30.3 source GigabitEthernet0/1
ntp server 85.214.108.169 source GigabitEthernet0/1
ntp server 78.46.70.42 source GigabitEthernet0/1
ntp server 188.40.77.71 source GigabitEthernet0/1
end
2 Accepted Solutions
The no ip routing command disables the ability to route any traffic between subnets, or even within its own subnet.
The router then becomes just like a host.
Please enable 'ip routing' , so this will enable the router to perform routing tasks between your connected subnets and should enable you to 'ping' between subnets too.
Also your nat statement is not correct. Kindly amend this to reflect:
ip nat inside source list 3 interface GigabitEthernet0/1
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
no ip nat outside source list 100 interface GigabitEthernet0/1
and modify this:
ip route 0.0.0.0 0.0.0.0 72.54.100.111  as this must be the next-hop not your router IP
Are you sure about this IP on the outside interface because it is a broadcast address with a /30 not a host address ?
Alain
6 Replies 6
evergreenajay
why you have configure " No ip routing" ?
I am not sure, I was going by an example. Is that my problem? What does no ip routing mean? Thanks!
Hope this helps
Thanks, below is my new config. I noticed now there is "Overload" next to the ip nat inside command?
Router1#show run
Current configuration : 6085 bytes
! Last configuration change at 13:28:57 EDT Wed Apr 24 2013
version 15.0
hostname Router1
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool myPool
   lease 7
crypto pki certificate chain TP-self-signed-2565028650
certificate self-signed 01
license udi pid CISCO1921/K9 sn FTX144601AF
username admin privilege 15 password 0 #nter2TBNA
ip nat inside
duplex auto
speed auto
no mop enabled
ip nat outside
duplex auto
speed auto
no ip http server
ip nat inside source list 3 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.1.21 80 72.54.100.111 80 extendable
ip nat inside source static tcp 192.168.1.21 443 72.54.100.111 443 extendable
ip nat inside source static tcp 192.168.1.99 1180 72.54.100.111 1180 extendable
ip nat inside source static tcp 192.168.1.4 1433 72.54.100.111 1433 extendable
ip nat inside source static udp 192.168.1.4 1433 72.54.100.111 1433 extendable
ip nat inside source static tcp 192.168.1.4 1434 72.54.100.111 1434 extendable
ip nat inside source static udp 192.168.1.4 1434 72.54.100.111 1434 extendable
ip nat inside source static tcp 192.168.1.157 3388 72.54.100.111 3388 extendable
ip nat inside source static udp 192.168.1.157 3388 72.54.100.111 3388 extendable
ip nat inside source static tcp 192.168.1.4 3389 72.54.100.111 3389 extendable
ip nat inside source static tcp 192.168.1.130 3394 72.54.100.111 3394 extendable
ip nat inside source static udp 192.168.1.130 3394 72.54.100.111 3394 extendable
ip nat inside source static tcp 192.168.1.3 3395 72.54.100.111 3395 extendable
ip nat inside source static udp 192.168.1.3 3395 72.54.100.111 3395 extendable
ip nat inside source static tcp 192.168.1.20 5631 72.54.100.111 5631 extendable
ip nat inside source static udp 192.168.1.20 5631 72.54.100.111 5631 extendable
ip nat inside source static tcp 192.168.1.20 5632 72.54.100.111 5632 extendable
ip nat inside source static udp 192.168.1.20 5632 72.54.100.111 5632 extendable
ip nat inside source static tcp 192.168.1.20 5800 72.54.100.111 5800 extendable
ip nat inside source static tcp 192.168.1.20 5801 72.54.100.111 5801 extendable
ip nat inside source static tcp 192.168.1.20 5900 72.54.100.111 5901 extendable
ip nat inside source static tcp 192.168.1.21 8080 72.54.100.111 8080 extendable
ip nat inside source static udp 192.168.1.21 8080 72.54.100.111 8080 extendable
ip nat inside source static tcp 192.168.1.21 8383 72.54.100.111 8383 extendable
ip nat inside source static udp 192.168.1.21 8383 72.54.100.111 8383 extendable
ip nat inside source static tcp 192.168.1.21 8384 72.54.100.111 8384 extendable
ip nat inside source static udp 192.168.1.21 8384 72.54.100.111 8384 extendable
ip nat inside source static tcp 192.168.1.21 17350 72.54.100.111 17350 extendable
ip nat inside source static udp 192.168.1.21 17350 72.54.100.111 17350 extendable
ip nat inside source static tcp 192.168.1.136 28192 72.54.100.111 28192 extendable
ip nat inside source static udp 192.168.1.136 28192 72.54.100.111 28192 extendable
control-plane
line con 0
line aux 0
line vty 0 4
password
login
ntp update-calendar
end
and modify this:
Alain
THanks!  I was changing the IP addresses for security reasons so it couldnt get hacked.
