Configuring a 2521 as a 4 port frame switch
bgriffis
I am setting up a lab for testing and playing with. In it I have a 2521 with 4 serial ports. 2 2524s with 2 serial ports each. A 2501 and a 2509.
I am able to configure and bring up point-to-point links wiht no problem, but wanted to try to do a fully meshed 4 port frame-relay switch.
I was able to do frame between the 2521 and one of the routers, but am running into trouble trying to get all 4 remote routers (2524-1, 2524-2, 2501, 2509) talking to each other over an emulated frame-relay network using the 4 serial ports on the 2521.
Anyone have a sample configuration from a fully meshed 4 port frame network using a 2521 (or similar) as the switch?
thisisshanky
Level 11
Level 11
frame-relay switching
int s0
frame-relay intf-type dce
clock rate 56000
frame-relay route 102 int s1 201
frame-relay route 103 int s2 301
framr-relay route 104 int s3 401
int s1
clock rate 56000
frame-relay route 201 int s0 102
frame-relay route 203 int s2 302
frame-relay route 204 int s3 402
int s2
clock rate 56000
frame-relay route 301 int s0 103
frame-relay route 302 int s1 203
frame-relay route 304 int s3 403
int s3
clock rate 56000
frame-relay route 401 int s0 104
frame-relay route 402 int s1 204
frame-relay route 403 int s2 304
Easy way to do this is,
a. understand the syntax of the frame-relay route configuration.
b. chart out the different PVCs for the full mesh. (A picture is worth a 1000 words)
c. Number of pvc's with N sites - N(N-1)/2 = 4*3/2 = 6 PVCs to interconnect all sites in a full mesh.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thisisshanky
Level 11
Level 11
int s0
clock rate 56000
int s1
clock rate 56000
int s2
clock rate 56000
int s3
clock rate 56000
Sankar Nair
Thanks! That is a thing of beauty! I configured the 2521 as above, and have a great start. I'll bring up a few of the remtoe routers and configure their frame connections next. I'll let the routers discover the frame cloud first, then manually configure.
