Configuring a Cisco 2690 Switch for Practice
dr3amHigher
Hello everyone, I am still a student and fairly new at this stuff. I am configuring a Cisco 2690 switch to practice against. It is plugged up via the console cable to my computer and I am using SCREEN to configure it. I have reset it to factory settings then did the initial configuration
Steps to factory reset:
Hold down mode while powering on machine, opened terminal and did screen [file location]
switch: flash_init
switch: del flash:config.text
switch: del flash: vlan.dat (no file for this)
switch: boot
Would you like to enter the initial configuration dialog? [yes/no]:
% Please answer 'yes' or 'no'.
host name: myswitch
// set passwords
Configure SNMP Network Management? [no]: no
Enter interface name used to connect to the
management network from the above interface summary: vlan1
Configure IP on this interface?[yes]: no
 I did not set the IP because I need to set up this as a DHCP server to serve me an IP so that I can SSH into it.
myswitch>enable
myswitch#configure terminal
myswitch(config)#ip dhcp excluded-address 192.168.1.1 192.168.1.10
myswitch(config)#ip dhcp pool test
myswitch(dhcp-config)#network 192.168.1.0 255.255.255.0
myswitch(dhcp-config)#default-router 192.168.1.1
myswitch(dhcp-config)#dns-server 4.4.4.4
myswitch(dhcp-config)#exit
myswitch(config)#interface vlan 1
myswitch(config-if)#ip address 192.168.1.5  255.255.255.0
myswitch(config-if)#no shutdown
myswitch(config-if)#exit
myswitch(config)#exit
myswitch#
and I enabled SSH
 myswitch# config t
//left out ip domain-name
// Generate RSA keys for encryption myswitch(config)# crypto key generate rsa Choose the size of the key modulus in the range of 360 to 2048 for your General Purpose Keys. Choosing a key modulus greater than 512 may take a few minutes. How many bits in the modulus [512]: 512 Choose 1024 if you want higher security. Configure VTYs (Virtual Terminal Lines) myswitch(config)# line vty 0 4 myswitch(config-line)# login local myswitch(config-line)# transport input ssh myswitch(config-line)# exit myswitch(config)# username [name] password [password] Set time-out interval myswitch(config)# line vty 0 4 myswitch(config-line)# exec-timeout 5
myswitch#show ip int brief (Only Vlan1 is showing with the ip address I created)
myswitch# sh ip ssh (SSH is showing as enabled)
The SSH does not work and I am unsure of what else I'm missing on this.
Hello
ip dhcp pool test
dns-server 4.4.4.4
interface vlan 1
no shutdown
The dhcp server doesn’t have the correct D/G in the dhcp pool I would say its need to be 192.168.1.5
Also are you able to obtain an ip address from this dhcp pool, Is the routed vlan 1 interface actually up, if not you need to enable an access port for that routed interface to come up, as I am assuming you have no trunks links?
sh ip int brief
Kind Regards
Paul
6 Replies 6
Richard Burts
We have some information but not enough to be able to identify the problem. You have indicated that you have a console connection to the switch and that works. You have assigned an IP address to vlan 1 and you have enabled ssh. This is a good start. But we need more information. Where are you attempting to test ssh from? Is it a device that is connected to the switch? Does that device have an IP address? If so what is its IP address? Can that device ping the IP address of the switch?
Rick
I am attempting to test from a terminal on the computer the switch is connected to. I just tried to ping the switch's IP address and that did not work.
Thanks for the additional information. If ping is not successful then there is a problem with IP connectivity. And problems with IP connectivity will prevent SSH from working. So testing for connectivity is a good first step in investigating problems using SSH.
So the computer is connected to the switch using an Ethernet cable to connect the Ethernet port of the computer to an interface on the switch. Is that correct? Does the computer have an IP address on its Ethernet interface? Can you post the output of ipconfig on the computer?
Rick
Can you post-show run full config to look or follow below guide :
https://ipwithease.com/how-to-configure-ssh-version-2-on-cisco-router/
BB
the switch configuration is by the book. You need to be able to ping the Vlan 1 interface (obviously) for SSH connectivity to work. What 'terminal' are you trying to connect from ? Is that terminal's IP address in the 192.168.1.0/24 range ?
Hello
ip dhcp pool test
dns-server 4.4.4.4
interface vlan 1
no shutdown
sh ip int brief
Kind Regards
Paul
