Configuring Backup Link (Dual Link To Internet)
tomocisco
Hi All,
Thanks for your ever helpful contributions that has continued to enrich our professional outputs.
I am dealing with an issue presently on my network.
I want to configure my router for a dual link to the internet so that when one link goes down the other comes up automatically and once the primary link is restored it switches to it automatically.
I know I am supposed to use different admin distances to show which is the main link and backup link but I am not very sure about how NAT will work with this and how it will affect my Vpn connection which I'm still troubleshooting. I.e. will the backup link automatically use the vpn?
My current config for primary linkis shown.
Building configuration...
Current configuration : 5673 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service dhcp
hostname
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login local_auth local
aaa session-id common
crypto pki trustpoint TP-self-signed-3885639516
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3885639516
revocation-check none
dot11 syslog
no ip source-route
no ip gratuitous-arps
ip cef
ip dhcp bootp ignore
no ip bootp server
no ip domain lookup
ip domain name
ip name-server 19.8.8.8
ip name-server 4.9.0.0
username a
username to
crypto isakmp policy 1
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key scisc address 4.x.x.x
crypto ipsec transform-set ME-VPN esp-aes esp-md5-hmac
crypto map VPN-TO-PH 10 ipsec-isakmp
set peer 4.x.x.x
set transform-set ME-VPN
match address VPN-TRAFFIC
archive
log config
  logging enable
  hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
interface Loopback0
ip address 192.1.1.1 255.255.255.255
interface Tunnel0
no ip address
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address 41.y.y.y 255.255.255.248
ip verify unicast source reachable-via rx allow-default 101
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 4.x.x.x
ip route 192.168.1.0 255.255.255.0 FastEthernet1
ip http server
ip http access-class 20
ip http authentication local
ip http secure-server
ip nat inside source route-map LAT interface FastEthernet1 overload
ip access-list extended VPN-TRAFFIC
permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
logging trap debugging
logging facility local2
access-list 20 permit 192.168.0.111
access-list 100 remark EXCLUDE NAT
access-list 100 deny   ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 permit udp any any eq bootpc
no cdp run
route-map LAT permit 1
match ip address 100
control-plane
line con 0
exec-timeout 5 0
password
login authentication local_auth
transport output telnet
line aux 0
line vty 0 4
privilege level 1
password
transport input telnet ssh
line vty 5 193
privilege level 1
password
end
Any one with an idea how to achieve this?
Tom
8 Replies 8
ahmad82pkn
Level 3
Level 3
Over load your Private IP Scheme on both Primary WAN Interface and Secondary WAN interface.
When traffic will move from one link to other link using distance ( in case of failure ) NAT of secondary interface will start working.
About VPN, create two VPN. one with Primary Link one with backup link.
Hi Ahmad,
Thanks for your post.
I added a backup link using this statement:
ip route 0.0.0.0 0.0.0.0 4.y.y.y 150
ip route 192.168.1.0 255.255.255.0 FastEthernet0 200
However when i tried to change NAT to overload using the backup interface f0, i got this message:
router(config)#ip nat ins sourc route-map NAT interface f0 overload
%Dynamic mapping in use, cannot change
router(config)#
Also i discovered that if i create a new vpn for the backup link, the existing link appears to be going down because i can't ping the remote network again.
I know that the route statement above will switch to use the backup route (higher admin distance) once the main link is down but does that mean that each time I will have to manually add Nat overload to the new interface?
Does any one has a different approach to this.
I will appreciate it.
Tom
Can you post your config.
Regards.
Alain
Hi Cadet,
The sho run is given below:
aaa new-model
rsakeypair TP-self-signed-3885639516
        quit
dot11 syslog
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name mastersenergyltd.com
ip name-server 19.t.t.t
ip name-server 4.2.3.3
ip name-server 192.168.0.2
login block-for 15 attempts 5 within 5
password encryption aes
encr aes
hash md5
group 2
crypto isakmp key 6 YNNZ address 4.y.y.y
set peer 4.y.y.y
archive
log config
  logging enable
  hidekeys
ip ssh time-out 60
interface Loopback0
ip address 192.100.100.1 255.255.255.255
interface Tunnel0
no ip address
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
shutdown
description BACKUP INTERNET LINK
ip address 4.z.z.z 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
ip address 4.d.d.d 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
switchport access vlan 100
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route 0.0.0.0 0.0.0.0 4.2.2.1
ip route 0.0.0.0 0.0.0.0 4.1.2.4 150
ip http server
access-list 20 permit 192.168.0.9
no cdp run
control-plane
line con 0
exec-timeout 5 0
password 7 01
line aux 0
line vty 0 4
privilege level 15
password 7 10
line vty 5 193
privilege level 15
password 7 01
end
The public IP addresses were changed.
Thomas
1) clear your nat mappings: clear ip nat trans *
2) remove your NAT statement: no ip nat inside source route-map LAT interface FastEthernet1 overload
3)create your 2 route-maps:
route-map PRIMARY permit 10
match ip add 100
match interface f1
route-map BACKUP permit 10
match ip add 100
match interface f0
3) create the 2 NAT statements:
ip nat inside source route-map PRIMARY interface f1
ip nat inside source route-map BACKUP interface f0/0
you should also configure a crypto map on the backup link with the correct settings.
Regards.
Alain.
gamalielcruz
I think you may have to use route maps in order to have dual NAT.
The NAT configuration would look like this:
ip nat inside source route-map map1 interface FastEthernet0/0 overload
ip nat inside source route-map map2 interface FastEthernet1/0 overload
Maps 1 and 2 would contain your match statements to match to an access-list for your private IP addresses and to match to each of your WAN interface.
Hi Gamalielcruz,
Thanks for your response.
I have a route map statement:
I created another one
route-map NAT permit 1
But when I try to tie this to a NAT statement, the vpn goes down.
Or is there any other way to get this done using route map.
Thanks.
Tom
Have you put match interface statements to those route-maps? These would indicate which interface the particular route-map would send out the route to.
