Configuring C1117-4P Router
craig88
We have been asked by a potential new customer to configure a self-purchased Cisco C1117-4P router with their new BT internet line. Another company is installing a SonicWALL firewall.
We are just waiting for the SFP module for port 0/0/0 to patch the SC Fibre cable into it.
I have drafted some commands but am unsure if this is correct as my Cisco knowledge is very limited. The Router will have a SonicWALL firewall connected to port 0/1/0 via RJ45 which is an L2 port, so unable to assign an IP address to the port, I believe we would need to configure a VLAN for that port.
The ISP provided us with a /30 address, for example, let's say the below details:
IP Address: 152.0.0.152/30
Gateway Address: 152.0.0.151
That 152.0.0.152 address is being used for the 0/0/0 port for internet access on the Router, and then I used the 152.0.0.151 gateway address on the IP route between the router and ADVA.
!0/0/0 patched directly to the ADVA
config t Int 0/0/0
Description INTERNET
ip address {ISP_/30_ADDRESS} 255.255.255.252
ip nat outside
no shutdown
exit
ip nat inside source list 1 interface gigabitethernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 {ISP_GATEWAY_IP}
access-list 1 permit 10.10.1.0 0.0.0.255
line vty 0 4
access-class 1 in
line vty 5 15
access-class 1 in
spanning-tree mode rapid-pvst
vlan 10
name FIREWALL
int vlan 10
description FIREWALL
ip address 10.10.1.2 255.255.255.0
ip nat inside
no shutdown
!Patched into the SonicWALL Firewall
interface gi0/1/0
switchport mode access
switchport access vlan 10
spanning-tree portfast
no shutdown
Will this now work, or am I still missing something to get the internet working on the router and then pass that through to the firewall?
7 Replies 7
"The Router will have a SonicWALL firewall connected to port 0/1/0 via RJ45 which is an L2 port"
Do you mean, the firewall is L2 ?
You need to add a default route on the router pointing to firewall.
How would said default route look on the Router?
ip route  0.0.0.0  0.0.0.0   X.X.X.X > Firewall
Ah OK gotcha, so looks like this now then:
ip route 0.0.0.0 0.0.0.0 10.10.1.2 < FIREWALL IP
line vty 0 4
access-class 1 in
line vty 5 15
access-class 1 in
craig88
So.... Just been updated, apparently, the plan has been changed now... Now the firewall is connecting to the ADVA and we are using the router to separate traffic across 2 VLANs for 2 companies sharing office space.
Would this router be best for that or should we now look at a different option for this?
It depends on the size of your customer.
think looking at 20 each side, they don't want to be able to communicate with each business on the network
