Configuring Channelized DS3 for DS1's and DS0's
tiki_turtle
I have configured our controller 3/0/1 for 28 channels - The first 27 are for T1's and the last channel 28 is sliced into DS0's. The T1's to connect to their specific channels no problem. I have issues however with 64K lines to channel 28.
Controller information - I setup the controllers..
controller T3 3/0/1 -
t1 1 channel-group 0 timeslots 1-24
t1 2 channel-group 0 timeslots 1-24
t1 3 channel-group 0 timeslots 1-24
t1 4 channel-group 0 timeslots 1-24
t1 5 channel-group 0 timeslots 1-24
t1 6 channel-group 0 timeslots 1-24
t1 7 channel-group 0 timeslots 1-24
t1 8 channel-group 0 timeslots 1-24
t1 9 channel-group 0 timeslots 1-24
t1 10 channel-group 0 timeslots 1-24
t1 11 channel-group 0 timeslots 1-24
t1 12 channel-group 0 timeslots 1-24
t1 13 channel-group 0 timeslots 1-24
t1 14 channel-group 0 timeslots 1-24
t1 15 channel-group 0 timeslots 1-24
t1 16 channel-group 0 timeslots 1-24
t1 17 channel-group 0 timeslots 1-24
t1 18 channel-group 0 timeslots 1-24
t1 19 channel-group 0 timeslots 1-24
t1 20 channel-group 0 timeslots 1-24
t1 21 channel-group 0 timeslots 1-24
t1 22 channel-group 0 timeslots 1-24
t1 23 channel-group 0 timeslots 1-24
t1 24 channel-group 0 timeslots 1-24
t1 25 channel-group 0 timeslots 1-24
t1 26 channel-group 0 timeslots 1-24
t1 27 channel-group 0 timeslots 1-24
t1 28 channel-group 0 timeslots 1
t1 28 channel-group 1 timeslots 2
t1 28 channel-group 2 timeslots 3
router#sh controllers t3 3/0/1 brief
T1 2 is up
timeslots: 1-24
FDL per AT&T 54016 spec.
No alarms detected.
Framing is ESF, Clock Source is Internal
T1 3 is down
timeslots: 1-24
Transmitter is sending LOF Indication.
Receiver is getting AIS.
T1 4 is up
timeslots: 1-24
No alarms detected.
Framing is ESF, Clock Source is Internal, Rx throttles 7
T1 5 is down
timeslots: 1-24
T1 28 is up
timeslots: 1-3
No alarms detected.
What am I missing - Should linecode be configured - if so how - The only commands I can use are
router(config-controller)#t1 28 ?
bert Start BERT test
channel-group Specify a channel-group mapping on a T1 interface
clock Specify the clock source for a T1
fdl Specify the Facility Data Link for a T1
framing Specify the type of Framing on a T1
logging-events Log T3 events
loopback Put the T1 line into loopback
yellow Yellow Alarm Configuration for a T1
much thanks
Not applicable
The following procedure describes how to perform a basic controller configuration. After you verify that the new line card is installed correctly, enter the privileged EXEC mode with the enable command. The system prompts you for a password if one is required. Use the configure command to configure the controller.
http://www.cisco.com/en/US/products/hw/modules/ps2710/prod_configuration_guide09186a00801fd56a.html#wp455719
http://www.cisco.com/en/US/products/hw/modules/ps2710/ps169/tsd_products_support_model_home.html
