Configuring cisco 1921
Philipvanbeeck
I'm trying to configure a cisco 1921 with our new provider and I am having some problems. With the config below I can ping hosts from the router, but not from the private ip's. The info I got from the ISP:
wan route: x.x.x.220/30
isp ip address: x.x.x.221
customer ip address: x.x.x.222
public ip's: y.y.y.224/29
Philip
Building configuration...
Current configuration : 4449 bytes
version 15.1
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service udp-small-servers
service tcp-small-servers
service sequence-numbers
hostname cisco1921
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
no ipv6 cef
ip source-route
ip gratuitous-arps
ip cef
ip name-server 195.130.131.11
redundancy
ip finger
ip tcp synwait-time 10
no ip ftp passive
interface Embedded-Service-Engine0/0
no ip address
ip mask-reply
ip directed-broadcast
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$FW_INSIDE$
ip address 192.168.0.3 255.255.255.0
ip mask-reply
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$
ip address x.x.x.222 255.255.255.252
ip mask-reply
ip flow ingress
ip nat outside
duplex auto
speed auto
ip default-gateway x.x.x.221
ip forward-protocol nd
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.221
ip identd
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 deny any
no cdp run
control-plane
end
Edison Ortiz
public ip's: y.y.y.224/29 are assigned for your hosts and you haven't done so in your router configuration.
The easiest approach is configuring nat pools
For instance:
ip nat pool NETPRO y.y.y.y.201 y.y.y.206 netmask 255.255.255.248
ip nat inside source list 1 pool NETPRO
Edison Ortiz
For instance:
