configuring cisco router as CPE
Hi all
we are changing our internet service, the provider is requiring a Cisco 4351 router and they will provide us with 2 sets of public IPs
first set is /30 will be used for the WAN    lets say xx.xx.xx.xx/30
second set will be /26 for our LAN use     lets say yy.yy.yy.yy/26
both are public
correct me if am wrong about what i need to do on the router
define the yy.yy.yy.yy/26 subnet
set the WAN port with xx.xx.xx.xx first IP
set default route 0.0.0.0 to use the xx.xx.xx.xx second IP
set the DNS
also my LAN port will be connected to my firewall where all the public IPs are used and configured so i will need the LAN port to bypass the LAN subnet to the firewall, do i have to do secondary IPs?
i know it should be an easy job but its critical and i wan to make sure i am ready to switch with no down time
thanks
Now I understand your concern.
answer is , your isp router has to point to your wan IP address for /26 net.
ip route x.x.x.x 255.255.255.192 your-Isr-wan-address
on your lan interface
int gi0/0/1
desc LAN interface
ip address y.y.y.y 255.255.255.192
no shut
and on global
Ip route 0.0.0.0 0.0.0.0 your-isp-wan-address
on firewall
ip route 0.0.0. 0.0.0.0 your-Isr-lan-address
just make sure your isp router has a static route for /26 pointing to your Isr-wan-address
10 Replies 10
rais
Level 7
Level 7
Usually 1st IP of a /30 is for ISP itself. So CPE should be the 2nd IP.
You can simply put a route for /26 on CPE with next-hop to the FW-LAN-IP - no secondary IPs required.
HTH.
thanks for the reply :)
i didnt understand the last part, so the /26 is public too but its going to be used after the router by the firewall
the port facing the firewall should bypass all the /26 IPs to it
thanks
Simon Ko
I think what you are doing is splitting two network on two devices.
/30 will go to WAN port and /26 will go to the Firewall.
But, if your firewall's external interface has the /26 address configured, you have to use one of /26 address for ISR's LAN interface.
If your firewall has dmz configured as /26 address. you can use private address between firewall's external interface and ISR's LAN interface.
You just have to point 0.0.0.0 route on firewall to ISR's LAN address and ISR's /26 network point to Firewall's external address.
Hope this make sense.
thanks again for reply
what am doing is this:
firewall has interfaces that uses the public set /26 so what i understand now is this
interface on firewall facing cisco router is part of /26 subnet
0.0.0.0 route is set on cisco using the router  WAN as GW
my question is: what do i need to do to define the /26 subnet on cisco router ?
if you can write the commands needed for all this setup i appreciate :)
int gi0/0/1
desc LAN interface
no shut
and on global
on firewall
int gi0/0/1
desc LAN interface
no shut
and on global
on firewall
great!
thanks a lot!
one last question
by this command
x.x.x.x is the subnet address not single IP, no?
Simon
i think i mad a mistake
you meant on the ISP not on the CPE router
yes?
