Configuring controllers in Cisco 2620
pie8terrr
I am somewhat new to cisco IOS. We have full T1 line terminated at cisco 2620 (IOS 12.3)with the integrated CSU/DSU. It has two interfaces FastEthernet 0/0 (LAN) and Serial 0/0 (T1). At least that's what the router shows when I execute the command 'show int'.
I've been seeing a lot of frame drops in the serial0/0 interface and CRC error. Here is what my router shows (1wd4 stat):
Input queue: 0/75/0 (size/max/drops); Total output drops: 404021
Queueing strategy: weighted fair
Output queue: 0/1000/64/404021 (size/max total/threshold/drops)
Conversations 0/130/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 98000 bits/sec, 88 packets/sec
5 minute output rate 606000 bits/sec, 698 packets/sec
493258 packets input, 80216893 bytes, 0 no buffer
Received 505 broadcasts, 0 runts, 0 giants, 0 throttles
2034 input errors, 540 CRC, 0 frame, 0 overrun, 0 ignored, 0 abor
3463399 packets output, 419484254 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
My ISP asked me to check the frame type and clock source. They said it should be ESF for frame and line for clock source. Looking through IOS 12.3 documentation, I see one of the controllers (either E1 or T1) has these settings. But if I execute the 'show controller e1' or 'show controller t1', I see nothing or even errors. The router goes back to command prompt as if nothing is configured for E1 or T1.
So my question is where would I go to set these configs?
pkhatri
Level 11
Level 11
'show controller t1 0/0' should show you these settings ....
Paresh
This is what I get if I type 'show controller t1 0/0'
router#show controller t1 0/0
% Invalid input detected at '^' marker.
router#
But if I enter 'show controller serial 0/0', this is what I get:
router#show controller se 0/0
Interface Serial0/0
Hardware is PowerQUICC MPC860 with Integrated FT1 CSU/DSU mo
TX and RX clocks detected.
idb at 0x80C0E718, driver data structure at 0x80C14674
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00008000
Mask [CIMR]=0x40204000, In-srv [CISR]=0x00000000
Command register [CR]=0x600
Port A [PADIR]=0x0000, [PAPAR]=0xFFFF
[PAODR]=0x0000, [PADAT]=0xE7FD
Port B [PBDIR]=0x0180F, [PBPAR]=0x0E00E
[PBODR]=0x0000E, [PBDAT]=0x3077D
Port C [PCDIR]=0x00C, [PCPAR]=0x000
[PCSO]=0x020, [PCDAT]=0xFC0, [PCINT]=0x00F
Receive Ring
rmd(68012830): status 9000 length 76 address 1B6DD44
rmd(68012838): status 9000 length 9E address 1B6F744
rmd(68012840): status 9000 length 86 address 1B71E44
rmd(68012848): status 9000 length 12A address 1B6A94
rmd(68012850): status 9000 length 55 address 1B695C4
router#
Thanks for the help
Ok, I see your problem. Try the following command: show service-module serial 0/0
Paresh.
PS. Pls do remember to rate posts
This is what I got. Now I can see clock source and framing type.
router#show service-module serial 0/0
Module type is T1/fractional
Hardware revision is 0.96, Software revision is 0.2,
Image checksum is 0xED22BEC5, Protocol revision is 0.1
Receiver has no alarms.
Framing is ESF, Line Code is B8ZS, Current clock source is line,
Fraction has 24 timeslots (64 Kbits/sec each), Net bandwidth is 1536 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 1d22h
loss of signal : 0,
loss of frame : 0,
AIS alarm : 0,
Remote alarm : 0,
Module access errors : 0,
Total Data (last 96 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in current interval (129 seconds elapsed):
Thanks.
So why didn't 'show controller t1 0/0' didn't work. Thanks
