QoS Low Latency Config and IP Precedence Question
mdargin
I want to apply the config below to allow all citrix (port 1494) to be marked with the precedence bit #2. The reason for this is my serial interface of the router at this remote location communicates through an MPLS network that has multiple routers (managed by Qwest) that it communicates through before it communicates with our central location. My service provider told me to mark all citrix traffic with the precedence value of 2 and they give it its proper priority when communicating through their MPLS WAN.
2 questions
Does the configuration below do the job of marking citrix traffic with precedence 2 so that the service provider can it its proper priority? What command command can I use to make sure that Citrix never consumes more than 65 percent of available bandwith even when available?
access-list 112 permit tcp any any precedence immediate eq 1494
class-map match-any citrix
match access-group 112
policty map citrixtraffic
class citrix
priority percent 65
int serial 0
service-policy output citrixtraffic
Thank You for any responses
pkhatri
Level 11
Level 11
That config won't quite achieve what yhou want. The priority command will police traffic to 65% on congestion but will allow the traffic to burst over it under times of no congestion.
Try the following config:
match protocol citrix
policy-map citrixtraffic
class citrix
shape average percent 65
set precedence 2
bandwidth percent 65
int serial 0
Paresh
PS. Pls do remember to rate posts.
