configuring dhcp on a switch
nygenxny123
does this statement indicate that
the switch will acquire a dhcp address
from the router?
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan134
ip address dhcp
no ip route-cache
ip http server
Im adding a switch to the network and
naturally want to make it standard with the other switches
mahmoodmkl
Level 7
Level 7
This is going to depend how u r connected to the other switch i.e u r connected through a trunk port or a access port,i think its not possible if u r connected with a trunk port with the other switch,if u r connected with a access port assigned in the vlan134 then u can get the ip address.
Mahmood
no...there is 1 switch connected to the routher
that is configured for dhcp-all other swiches
are hanging of this switch via trunks-since we have multiple vlans.
