07-25-2005 11:11 AM - edited 03-03-2019 10:07 AM
I know this is a slam dunk, i am new to Cisco Products, so learning the correct verbage and protocol is proving to be quite a task for me. I have an existing PIX 525 {OS 6.3(1)} with 4 VLANs. I am trying to change the DNS that is assigned by DHCP on ONE of the VLANs. The current DNS Server was suddenly decomissioned by my ISP and I need to get 1 or 2 DNS servers to replace the now ghost-like one. I am not sure how to specify which VLAN I am going to change and what is the correct verbage to use, I thank you all in advance for your help.
07-25-2005 06:15 PM
I think the command to be used is:
[no] dhcpd dns dns1 [dns2]
Check this link to the relevant PIX command reference:
dhcpd
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/df.htm#wp1025497
GP
07-25-2005 07:35 PM
thank you so much for your response!! I have one more question, how do i specify which VLAN to apply the DNS settings to?
07-25-2005 08:37 PM
I dont think the pix differntiates between different pools even though the pool might be differentiated by the
dhcpd ip
07-26-2005 07:09 AM
the [no] refers to what exactly?
when i type in the command
DHCPD DNS (DNS SERVER IP #)
it responds by insructing me to check my usage
the only thing I did not know what to fill in was the [no] variable.
