Configuring E&M trunk betwen two routers usgin LMR e-lead starts ON with no M signal
Lucas Reveand
Hi, I've configured a connection using E&M cards on Cisco 2900 Routers using LMR. The configurarion works great, the only caveat that I have found is that every time you boot the router, the LMR trunk set the e-lead to ON eventhough theres no m-lead applyed. The only way to "reset" the e-lead (I mean to switch it to OFF) is forcing m-lead signal and then take it out... I must do that on both sites fisically so is not really an option. Once I do the reset by forcing M on the port everything works just as expected.
Why my e-lead starts seted as ON?? Is this a normal behavior??
I found the comand "bootup e-lead off" but it has no effect so far.
Any advice on how can I avoid the e-lead to go ON every time the router boots up??
Here is site A config,
voice-port 0/0/0
 voice-class permanent 1
 operation 4-wire
 type 5
 signal lmr
 bootup e-lead off
 lmr m-lead audio-gate-in
 lmr e-lead voice
 no echo-cancel enable
 timeouts call-disconnect 3
 timing hookflash-in 0
 connection trunk 1000
dial-peer voice 1 pots
 destination-pattern 2000
 port 0/0/0
dial-peer voice 11 voip
 description TRUNK TO SITE B
 destination-pattern 1000
 session target ipv4:10.70.1.253
 ip qos dscp 5 media
 ip qos dscp 3 signaling
 no vad
Here is site B config,
voice-port 0/2/0
 operation 4-wire
 type 5
 signal lmr
 bootup e-lead off
 lmr e-lead voice
 connection trunk 2000
 port 0/2/0
dial-peer voice 10 voip
 session target ipv4:10.1.100.10
 ip qos dscp cs5 media
 no vad
Here's the output of the "show voice lmr" command on both sites just after a reload.
SITE A
0/0/0
Connection type: trunk
Connection Number is 1000
Out Attenuation = 0 dB, In Gain = 0 dB
E-lead capability is voice, polarity = normal
M-lead capability is audio-gate-in, polarity = normal
state = TRUNK_SC_CONNECT, e-lead = on, m-lead = off
full duplex, voice : rx, signal : on ,master
trunk status: rcv IDLE, trunk connected
voice packet detection enable
Originating side of the connection
TransmitPackets=477236, TransmitBytes=13362508
ReceivePackets=477461, ReceiveBytes=9549120
CoderTypeRate=g729r8
NoiseLevel=-84, ACOMLevel=3
OutSignalLevel=-66, InSignalLevel=-79
RemoteIPAddress=10.70.1.253, RemoteUDPPort=16400
Remote SignallingIPAddress=10.70.1.253, Port=1720
Remote MediaIPAddress=172.17.70.244 Port=16400
RoundTripDelay=24 ms
SessionProtocol=cisco
VAD =disabled
RTCP TransmitPackets=0
RTCP ReceivePackets=0
Video RTCP TransmitPackets=0
Video RTCP ReceivePackets=0
SITE B
0/2/0
 Connection Number is 2000
 Terminating side of the connection
 TransmitPackets=480580, TransmitBytes=13456140
 ReceivePackets=481413, ReceiveBytes=9628160
 RemoteIPAddress=10.1.100.10, RemoteUDPPort=16390
 Remote SignallingIPAddress=10.1.100.10, Port=50658
 Remote MediaIPAddress=10.1.100.10 Port=16390
 RoundTripDelay=26 ms
 VAD =disabled
Thanks in advance, Regards.
Lucas.-
0 Replies 0
