configuring ehwic-4esg module Proper cli commands
My issue is that I'm not able to find the correct documentation. Cisco active Advisor did in fact show the module is there and working.
The ones that do with the Cisco2951/K9 appear to be there with a show ip interface brief, keep getting this error.
%  IP addresses may not be configured on L2 links.
Any help would be greatly appreciated.
The Gods you Worship are Steele.
And at the alter of Rock 'N Roll you kneel.
Giuseppe Larosa
Hello @lacroixjamie201938782 ,
post
show diag
show inventory
to see if the module is correctly recognized by the router
the message:
this is just a warning telling that IP addresses cannot be configured on switch ports like the ones that the module provides so this should not be a serius issue. Instead, it can be the sign that the module is correctly recognized.
Hope to help
Giuseppe
C2951-UNIVERSALK9-M#show diag
Slot 0:
C2951 Mother board 3GE, integrated VPN and 4W Port adapter, 11 ports
Port adapter is analyzed
Port adapter insertion time 00:09:58 ago
Hardware Crypto Engine Details:
The CHIP id is 0x0
The SEC revision no is 0x1
EEPROM contents at hardware discovery:
PCB Serial Number : FOC17328HY3
Hardware Revision : 1.1
Part Number : 73-11836-08
Top Assy. Part Number : 800-30793-06
Board Revision : A0
Deviation Number : 0
Fab Version : 03
Product (FRU) Number : CISCO2951/K9
Version Identifier : V06
CLEI Code : CMMKD00ARA
Processor type : C8
Chassis Serial Number : FTX1740AJCH
Chassis MAC Address : c067.af78.a940
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 37 33 32 38 48 59 33 40
0x10: 06 15 41 01 01 82 49 2E 3C 08 C0 46 03 20 00 78
0x20: 49 06 42 41 30 88 00 00 00 00 02 03 CB 8C 43 49
0x30: 53 43 4F 32 39 35 31 2F 4B 39 89 56 30 36 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4B 44 30 30 41 52
0x50: 41 09 C8 C2 8B 46 54 58 31 37 34 30 41 4A 43 48
0x60: C3 06 C0 67 AF 78 A9 40 43 00 60 C4 08 00 00 00
0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply information
Top Assy. Part Number : 341-0226-03
PCB Serial Number : DCA1724K0D3
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V03
Product (FRU) Number : PWR-2921-51-AC
CLEI Code : 0000000000
Board Revision : A0
0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 03 88 00 00 00
0x10: 00 C1 8B 44 43 41 31 37 32 34 4B 30 44 33 03 00
0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8E 50 57
0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
0x50: 05 F8 00 50 01 F3 18 3B 02 F0 19 D9 03 E8 1B 76
0x60: 04 E2 1C 49 05 D9 1D 1B 06 D8 1D ED 07 CF 1E BF
0x70: 08 CE 1F 40 09 C2 1F B8 0A B8 20 34 0B B7 20 B0
0x80: 0D AF 21 0C 0F 9F 21 67 11 91 21 94 13 87 21 C0
0x90: 17 6E 21 DB 1B 57 21 EA 1F 3F 21 E2 23 28 21 D4
0xA0: 27 0A 21 CD 42 41 30 FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
4 Port GE Switch
PCB Serial Number : FOC18417N3A
Hardware Revision : 1.0
Part Number : 74-7105-01
Board Revision : E0
Product (FRU) Number : EHWIC-4ESG
Version Identifier : V01
CLEI Code : COUIA46CAA
Base MAC Address : 881d.fc9f.b648
MAC Address block size : 8
0x00: 04 FF 40 06 B5 C1 8B 46 4F 43 31 38 34 31 37 4E
0x10: 33 41 41 01 00 82 4A 1B C1 01 42 45 30 88 00 00
0x20: 00 00 CB 8A 45 48 57 49 43 2D 34 45 53 47 89 56
0x30: 30 31 20 D9 03 40 C1 CB C6 8A 43 4F 55 49 41 34
0x40: 36 43 41 41 CF 06 88 1D FC 9F B6 48 43 00 08 FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
4 Port GE Switch
PCB Serial Number : FOC162171D4
Board Revision : C0
Base MAC Address : d48c.b542.41a0
0x00: 04 FF 40 06 B5 C1 8B 46 4F 43 31 36 32 31 37 31
0x10: 44 34 41 01 00 82 4A 1B C1 01 42 43 30 88 00 00
0x40: 36 43 41 41 CF 06 D4 8C B5 42 41 A0 43 00 08 FF
--More-- (192 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
Total platform memory : 4194304K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x20000000
Number of blocks of memory for 2nd core : 1
2nd core configured disabled
L2 cache ways for 2nd core
show in ventory
C2951-UNIVERSALK9-M#show inventory
NAME: "CISCO2951/K9", DESCR: "CISCO2951/K9 chassis, Hw Serial#: FTX1740AJCH, Hw Revision: 1.1"
PID: CISCO2951/K9 , VID: V06 , SN: FTX1740AJCH
NAME: "4 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 0", DESCR: "4 Port GE Non-POE EHWIC Switch"
PID: EHWIC-4ESG , VID: V01 , SN: FOC18417N3A
NAME: "4 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 1", DESCR: "4 Port GE Non-POE EHWIC Switch"
PID: EHWIC-4ESG , VID: V01 , SN: FOC162171D4
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC , VID: V03 , SN: DCA1724K0D3
the output of the two commands show that the modules are correctly recognized.
The only point of attention here is that you have two modules of the same type installed in different slots.
However, you should be fine from what we have seen
Hope to help
Giuseppe
