Do I use DHCP Server or Pool Manager
lam32123
I have configured gig 0/0/0 to connect to my ISP with ip address dhcp and ip nat outside --- my Cisco isr4331 router accepts the dynamic ip address and connects.  Now --- I want to configure gig 0/0/1, gig 0/1/0 and gig 0/1/1 to automatically address from a range of 30 ip addresses.  I have been studying "Cisco IP ADDRESSING: DHCP CONFIGURATION GUIDE" ?????
In order to automatically address from a range of 30 ip address, do I need to configure the DHCP Server  or  DHCP Server on-demand address pool manager?  I'm a beginner and believe we all have to start some where ---------- thanks for your help (it should save much trial and error).
2 Accepted Solutions
add the lines marked in bold to your configuration:
Current configuration : 1734 bytes
version 15.5
no platform punt-keepalive disable-kernel-core
hostname ThreeBears
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret cisco1
enable password cisco2
no aaa new-model
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
subscriber templating
license udi pid ISR4331/K9 sn FDO203323N0
username webui privilege 15 password 0 cisco
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description WAN
ip address dhcp
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
description LAN1
--> ip nat inside
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
vrf forwarding Mgmt-intf
ip address 198.162.1.1 255.255.255.0
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
--> ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
--> access-list 1 permit 192.168.1.0 0.0.0.255
snmp-server community public RO
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco3
login
end
make sure all of the below is in your configuration:
ip dhcp excluded-address 172.16.1.30
interface gigabitethernet0/0/1
description LAN
ip address 172.16.1.30 255.255.255.0
ip nat inside
ip nat inside soure list 1 interface GigabitEthernet0/0/0 overload
access-list 1 permit 172.16.1.0 0.0.0.255
10 Replies 10
pmckenzie
Level 3
Level 3
Not sure I'm with you on this.
Are you asking if the ISP can supply multiple different IP address for your interfaces gi0/0/1 gi 0/1/0 & gi 0/1/1
In which case the answer is no. It can only supply a DHCP address for your connected interface(s).
Normally you would then assign each of the above interfaces the IP addresses from your range of 30 ip addresses. The hosts connected to these (gi0/0/1 gi 0/1/0 & gi 0/1/1) could then be assigned DHCP addresses from your ISR4000.
There are worlds out there where the sky is burning, where the sea's asleep and the rivers dream, people made of smoke and cities made of song. Somewhere there's danger, somewhere there's injustice and somewhere else the tea is getting cold" Dr Who
as a matter of fact, it is not a good idea to use DHCP for IP addressing your fixed interfaces. You need to assign static IP addresses to the interfaces, and if you use a DHCP pool for clients, exclude these addresses from the pool:
ip dhcp pool LAN
description LAN
ip addess 192.168.1.1 255.255.255.0
The On-Demand Address Pool Manager is used for MPLS and non-MPLS VPN client addressing, not for assigning IP addresses to local router interfaces.
IT WORKS !!!!!
The router now assigns ip address as needed to GigabitEthernet0/0/0 ----- however I do not have communication to my internet service provider. I'm presently using the following:
interface gigabitethernet 0/0/0
ip address dhcp
ip nat outside
no shutdown
This code connects the router to my isp, and accepts a dynamic ip address. Any suggestions on how to get my LAN talking to my isp??? You help is appreciated
post the full running configuration (sh run) of your router. You are probably missing some NAT or access list related details.
ThreeBears#show run
Building configuration...
version 15.5
hostname ThreeBears
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip dhcp pool LAN
redundancy
mode none
description WAN
ip address dhcp
ip nat outside
negotiation auto
description LAN1
negotiation auto
no ip address
shutdown
negotiation auto
negotiation auto
interface Vlan1
no ip address
shutdown
ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco3
login
end
ThreeBears#
version 15.5
hostname ThreeBears
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip dhcp pool LAN
redundancy
mode none
description WAN
ip address dhcp
ip nat outside
negotiation auto
description LAN1
--> ip nat inside
negotiation auto
no ip address
shutdown
negotiation auto
negotiation auto
interface Vlan1
no ip address
shutdown
ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco3
login
end
Hello
Even though a router can perform dhcp service, its not to say it recommended for it to do so, Having a dedicated server would be a better option especially if you anticipate growth and want to incorporate registration with DNS/Active Directory however as you are querying how a rtr can become a dhcp server and to run multiple dhcp scopes allocating upto 30 ip addresses the following example may be applicable.
Example
ip dhcp pool dhcp_sever
network 172.16.1.0 255.255.255.224
default-router 172.16.1.30
network 172.16.1.32 255.255.255.224 secondary
override default-router 172.16.1.62
network 172.16.1.64 255.255.255.224 secondary
override default-router 172.16.1.65
network 172.16.1.96 255.255.255.224 secondary
override default-router 172.16.1.126
dns-server x.x.x.x y.y.y.y
domain-name test.com
lease 0 8
ip dhcp excluded-address <range of ips you wish not to be allocated, the default router of each scope is automatically excluded.
Kind Regards
Paul
Paul, thank you for your halp.  I have entered:
router(config)# interface gigabitethernet0/0/0
router(config-if)# description WAN
router(config-if)# ip address dhcp
router(config-if)# ip nat outside
router(config-if)# no shutdown
router(config-if)# exit
router(config)# ip dhcp pool dhcp_server
router(dhcp-config)# network 172.16.1.0 255.255.255.224
router(dhcp-config)# default-router 172.16.1.30
router(dhcp-config)# exit
router(config)# interface gigabitethernet0/0/1
router(config-if)# description LAN
router(config-if)# ip address 172.16.1.30 255.255.255.0
It assigns ip addresses correctly.  However, No communication to isp with dynamic ip address.  I get syntax error trying to enter dns-server line
description LAN
ip nat inside
I honestly did not see the similarity of these two solutions until I had to troubleshooting my work.  BOTH ip address 192.168.1.1 solution and ip address 172.16.1.30 solution work.  I chose the 172.16.1.30 solution because the 192.168.1.1 ip address seems to be VERY commonly used for switch / router addressing.   I'm a beginner, and without this community helping, I would NEVER have gotten even basic functions programmed into this router.  Thank you very much............................
