Configuring EIGRP on NX-OS while using custom VRF
tcmckay
I am trying to get my eigrp routing to work while using non-default vrf's Within the default vrf the configuration was pretty similar to IOS but when I try to configure it to run in my secure VRF I cannot seem to get it to work. Any idea's will help.
nxa# sh run eigrp
!Command: show running-config eigrp
!Time: Wed Nov 14 06:45:58 2018
version 7.0(3)I7(1)
feature eigrp
router eigrp DC
  autonomous-system 10
  router-id 192.168.3.1
router eigrp test
  autonomous-system 20
  router-id 192.168.3.2
interface Vlan8
  ip router eigrp DC
interface Vlan601
  ip router eigrp DC
interface loopback1
  ip router eigrp DC
That is the basic config for the default vrf. I have this on each of my 4 switches and the neighbor relations are created
nxa# sh ip eigrp ne
IP-EIGRP neighbors for process 10 VRF default
H   Address                 Interface       Hold  Uptime  SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
3   10.8.8.4                Vlan8           13   15:37:37  106  636   0   42
0   10.8.8.5                Vlan8           13   15:45:54  101  606   0   39
1   10.8.8.7                Vlan8           12   15:37:57  96   576   0   30
4   10.8.8.8                Vlan8           11   15:37:18  73   438   0   16
5   10.8.8.9                Vlan8           12   15:31:22  63   378   0   15
2   10.200.2.12             Vlan601         13   15:55:20  95   570   0   32
IP-EIGRP neighbors for process 20 VRF default
My design with the NX-OS is simple. I have 2x 5 K's and 2x 9K's
I am using vrf Test for all my routing
nx5a# sh run int vl8
!Command: show running-config interface Vlan8
!Time: Wed Nov 14 06:50:55 2018
version 7.0(3)I7(1)
interface Vlan8
  description DomainInf
  no shutdown
  vrf member test
  no ip redirects
  ip address 10.8.8.6/24
  ip router eigrp DC
  hsrp version 2
  hsrp 8
    preempt
    priority 50
    timers  1  3
    ip 10.8.8.1
  ip dhcp relay address 10.10.1.12
nxa# ping 10.8.8.7
PING 10.8.8.7 (10.8.8.7): 56 data bytes
64 bytes from 10.8.8.7: icmp_seq=0 ttl=254 time=9.078 ms
64 bytes from 10.8.8.7: icmp_seq=1 ttl=254 time=9.501 ms
64 bytes from 10.8.8.7: icmp_seq=2 ttl=254 time=11.066 ms
64 bytes from 10.8.8.7: icmp_seq=3 ttl=254 time=9.032 ms
64 bytes from 10.8.8.7: icmp_seq=4 ttl=254 time=9.808 ms
--- 10.8.8.7 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 9.032/9.696/11.066 ms
Basic connectivity to a neighbor has been established when the vlans are configured for the default vrf. However, in production all my vlans are in the test vrf and when I move them out of the default into test eigrp stops working.
7 Replies 7
how do you configure your EIGRP, do you get into 'vrf context vrf' globally first ?
sw(config) vrf context test
sw(config) router eigrp DC
sw(config-router)autonomous-system 10
sw(config-router)eigrp router-id 10.0.0.3
sw(config) int vl 8
sw(config-int) vrf mem test
sw(config-int) ip 10.10.1.10/24
sw(config-int)ip router eigrp DC
I have looked at some docs and sample configs, try and leave the 'autonomous-system' out of the EIGRP config...
sw(config-router)--> no autonomous-system 10
sw(config) int vl 8
When I make that change things get worse...here is the sh eigrp when the AS is removed
nx9a# sh run eigrp
!Time: Wed Nov 14 14:56:29 2018
version 7.0(3)I7(1)
feature eigrp
router eigrp DC
network 10.10.1.0/24
interface Vlan4
ip router eigrp DC
interface Vlan8
ip router eigrp DC
interface Vlan11
ip router eigrp DC
interface loopback1
ip router eigrp DC
nx9a# sh ip eigrp ne
IP-EIGRP neighbors for process 0 VRF default
nx5a# sh ip eigrp ne
nx5a# sh ip eigrp ne vrf test
IP-EIGRP neighbors for process 0 VRF saas
WITH AS added the EIGRP DC (this is the recommended config for nx-os)
nx9a# sh run eigrp
!Time: Wed Nov 14 15:00:00 2018
version 7.0(3)I7(1)
feature eigrp
router eigrp DC
interface Vlan4
ip router eigrp DC
interface Vlan8
ip router eigrp DC
interface Vlan11
ip router eigrp DC
interface loopback1
ip router eigrp DC
(sec) (ms) Cnt Num
2 10.8.8.4 Vlan8 12 00:00:21 77 462 0 39
0 10.8.8.5 Vlan8 13 00:00:21 45 270 0 39
1 10.8.8.9 Vlan8 10 00:00:21 37 748 0 39
nx9a# sh ip eigrp ne vrf saas
IP-EIGRP neighbors for process 0 VRF test
When I remove the AS for this router I lose all my routes. When I add it back in the routes come back. My problem is that eigrp works properly if I keep all my vlans and interfaces in the default vrf. When I move them to a custom vrf....vrf <name tag> then I lose connectivity through eigrp.
You can see this I have vlan's inside default and the custom vrf
interface Vlan8
no shutdown
no ip redirects
ip address 10.8.8.8/24
ip router eigrp DC
hsrp version 2
hsrp 8
preempt
priority 20
timers 1 3
ip 10.8.8.1
interface Vlan11
no shutdown
vrf member test
ip address 10.10.1.13/24
ip router eigrp DC
nx9a# sh ip eigrp ne vrf test
(sec) (ms) Cnt Num
2 10.8.8.4 Vlan8 12 00:05:58 77 462 0 39
0 10.8.8.5 Vlan8 10 00:05:59 45 270 0 39
1 10.8.8.9 Vlan8 10 00:05:58 37 748 0 39
Odd. Are you in the default VDC ? You might want to try and create a new VDC, and then configure everything in that VDC...
As I was working on this I discovered a second layer to the EIGRP configs when using NX-OS. I now have EIGRP working in both the default VRF and in a Custom VRF. The actual config is pretty basic but finding where to configure it was a bit of a challenge.
router eigrp DataCenter
router-id 10.0.0.4
vrf TEST
router-id 10.0.0.4
The key is that when you want eigrp to work the initial "router eigrp <router name> puts you into the default vrf. If you want to add eigrp to a custom vrf you simply use "vrf <vrf name> while in the router eigrp configuration. Then you continue to configure it the same as any other eigrp configuration. Now my sh ip eigrp ne output is like this.
nxb(config-if)# sh ip eigrp ne
(sec) (ms) Cnt Num
0 10.8.4.9 Vlan4 13 00:34:06 34 204 0 6
nxb(config-if)# sh ip eigrp ne vrf test
IP-EIGRP neighbors for process 20 VRF test
(sec) (ms) Cnt Num
0 10.10.1.13 Vlan11 11 00:34:29 23 138 0 5
You will notice that I had to call the actual vrf that I wanted to see eigrp in.
My next challenge will be to route between the two vrf's!
Glad to know that you have found the solution for your own problem. Thanks for sharing it with us. And +5 for the good solution. When we see the working solution it is sort of obvious. But I agree that needing to use the vrf command in EIGRP configuration is not intuitive.
Rick
Rick
