How to prevail an static route over a directly connected network
jmprats
Level 4
Level 4
Hi, we have some overlapping networks in our WAN.
I need to route the traffic from 192.168.128.0 to one IP (10.3.4.7/32) through a VPN .
The problem is the router has got an interface with this network 10.3.0.0/16 and the administrative distance of directly connected networks is 0, which preveil over static route. How can I use the static route over the directly connected network?
Dave makes a very good point and deserves +5. The important thing to understand is that the administrative distance difference between connected routes and static routes only comes into play when we have a connected route and a static route for the same prefix. If we have a connected route for a /24 and a static route for a /32 then AD does not come into play. Any packet with destination for the specific host in the static route will use the static route while packets for all other destination in the subnet will use the connected route.
Rick
Rick
Hello
You may be able to use Policy based Routing (PBR) to manipulate the traffic path
Can you post the:
Sh ip route static
Kind Regards
Paul
dbeattie
From memory, assuming that this is just a standard IPSec VPN (i.e. not GRE-over-IPSec) I think you can add a static route to the /32 via the next hop address on the external (VPN peering) interface. This will cause the traffic to be routed that way and the encryption will simply happen on the way out if it falls within the encryption domain ACL. The /32 static route should always win over the /16 connected interface.
Please try this and let us know how you get on.
Hope this helps
Dave
Rick
Rick
I am glad that our responses have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions that have helpful information. One advantage of communities like this is having multiple people reading the questions and providing their own insight and suggestions.
Rick
Rick
