Configuring NAT Overload for 5 different sunets
lestmp
Im currently in the middle of configuring a network using NAT(Overload) with 5 Subnets needing to be translated. The Nat/DHCP router has 3 network interface cards, each with a router attached to it. DHCP works perfectly, However translation at the Network gateway is not taking place. Below is the show run for the DHCP/NAT router. Thanks in advance guys.
hostname Router
ip dhcp excluded-address 192.168.10.0 192.168.10.3
ip dhcp excluded-address 192.168.50.0 192.168.10.3
ip dhcp pool Vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool Vlan50
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
no ip cef
no ipv6 cef
interface GigabitEthernet7/0
ip address 193.168.10.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface GigabitEthernet8/0
ip address 192.168.30.2 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet9/0
ip address 192.168.40.2 255.255.255.0
ip nat inside
duplex auto
speed auto
router rip
version 2
network 192.168.30.0
network 192.168.40.0
network 193.168.10.0
ip nat inside source list 20 interface GigabitEthernet7/0 overload
ip classless
ip flow-export version 9
access-list 20 permit 192.168.10.0 0.0.0.255
access-list 20 permit 192.168.20.0 0.0.0.255
access-list 20 permit 192.168.50.0 0.0.0.255
access-list 20 permit 192.168.60.0 0.0.0.255
access-list 20 permit 192.168.70.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Rob B
Not that it is probably related, but your exclude statement has a typo:
If you can, try clearing the nat table with:  clear ip nat translation *
If it is still an issue, can you paste the output of "sh ip nat translations" and "sh ip nat statistics"
I also don't see a default gateway in the config.
the access list (20) includes the address space of the NAT outside interface. Change it as below. I would also include network 192.168.10.0 in RIP:
hostname Router
ip dhcp pool Vlan10
ip dhcp pool Vlan50
no ip cef
no ipv6 cef
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
router rip
version 2
ip classless
line con 0
line aux 0
line vty 0 4
login
