Configuring OSPF on sub-interfaces
Cisco Enthusiast
Community Member
Greetings everyone,
I'm seeking clarification on the functioning of OSPF in relation to sub-interfaces within a single router.
In my current setup, the physical interfaces are associated with the
192.168.1.0/24
network, while the sub-interfaces fall under the
10.0.1.0/24
range.
I'm specifically interested in understanding whether it's essential to include the network statement
network 192.168.1.0 0.0.0.255 area 0
in every VRF instance.
Here is my configuration:
myrouter#sh running-config
Building configuration...
Current configuration : 3841 bytes
version 15.0
hostname myrouter
boot-start-marker
boot-end-marker
vrf definition A
 address-family ipv4
 exit-address-family
vrf definition B
 address-family ipv4
 exit-address-family
vrf definition C
 address-family ipv4
 exit-address-family
vrf definition D
 address-family ipv4
 exit-address-family
enable secret X.X.X
enable password X.X.X
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1921/K9 sn FCZ1434C389
interface Loopback1
 vrf forwarding A
 ip address 10.0.0.1 255.255.255.255
interface Loopback2
 vrf forwarding B
 ip address 10.0.0.2 255.255.255.255
interface Loopback3
 vrf forwarding C
 ip address 10.0.0.3 255.255.255.255
interface Loopback4
 vrf forwarding D
 ip address 10.0.0.4 255.255.255.255
interface GigabitEthernet0/0
 bandwidth 100
 ip address 192.168.1.1 255.255.255.252
 ip ospf network point-to-point
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/0.1
 vrf forwarding A
 encapsulation dot1Q 10
 ip address 10.0.1.9 255.255.255.252
interface GigabitEthernet0/0.2
 vrf forwarding B
 encapsulation dot1Q 20
 ip address 10.0.1.13 255.255.255.252
interface GigabitEthernet0/0.3
 vrf forwarding C
 encapsulation dot1Q 30
 ip address 10.0.1.17 255.255.255.252
interface GigabitEthernet0/0.4
 vrf forwarding D
 encapsulation dot1Q 40
 ip address 10.0.1.21 255.255.255.252
interface GigabitEthernet0/1
 description unused available port
 ip address 192.168.1.5 255.255.255.252
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1.1
 vrf forwarding B
 ip address 10.0.1.10 255.255.255.252
interface GigabitEthernet0/1.2
 vrf forwarding C
 ip address 10.0.1.14 255.255.255.252
interface GigabitEthernet0/1.3
 vrf forwarding D
 ip address 10.0.1.18 255.255.255.252
interface GigabitEthernet0/1.4
 vrf forwarding A
 bandwidth 10
 ip address 10.0.1.22 255.255.255.252
interface ATM0/0/0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Serial0/1/0
 no ip address
 shutdown
 clock rate 2000000
router ospf 10 vrf A
 router-id 10.0.0.1
 log-adjacency-changes
 redistribute static subnets
 network 10.0.1.0 0.0.0.255 area 0
router ospf 20 vrf B
 router-id 10.0.0.2
router ospf 30 vrf C
 router-id 10.0.0.3
router ospf 40 vrf D
 router-id 10.0.0.4
router rip
 version 2
 network 192.168.1.0
router bgp 65000
 no synchronization
 no bgp log-neighbor-changes
 no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
snmp-server community public RO
control-plane
line con 0
 exec-timeout 0 0
 password cisco
line aux 0
 password cisco
 login
 modem InOut
 transport input all
 speed 115200
 flowcontrol hardware
line vty 0 4
 password cisco
 login
 transport input all
line vty 5 15
 password cisco
 login
scheduler allocate 20000 1000
end
myrouter#
Hi @Cisco Enthusiast ,
You are fine with just including the sub interface subnet
(10.0.1.0/24)
Adding the
192.168.1.0/24
does not serve any purpose, as this subnet belongs to the default VRF, so not part of any of the other VRFs.
5 Replies 5
Jamie_90
Frequent Visitor
Frequent Visitor
You do not need to include
 under any of the OSPF vrf instances. Not unless you're attempting to advertise the
192.180.1.0/24
via each vrf? Based on your configuration, i'm assuming not.
(10.0.1.0/24)
Adding the
192.168.1.0/24
Joseph W. Doherty
"I'm specifically interested in understanding whether it's essential to include the network statement
in every VRF instance."
Essential?
Based on your posted configuration, no, it's not essential.  For the reasons already noted by @Jamie_90 and @Harold Ritter.
From your question, and your config, possibly you're don't fully understand VRFs and/or subinterfaces.
Subinterface are the logical equivalent of independent L3 interfaces, which just happen to physically share the same physical interface (conceptionally, much like multiple VLANs sharing a Cisco trunk interface).
VRF create totally different L3 domains (conceptionally much like L2 VLANs).
For example, you can do this:
 bandwidth 100
 ip address 10.0.1.10 255.255.255.252 !<<==
 duplex auto
 speed auto
 no mop enabled
 vrf forwarding B
 vrf forwarding C
 vrf forwarding D
 vrf forwarding A
 bandwidth 10
Do understand why the above is valid?
Hello and thank you for the response.
Yet assigning
10.0.1.10
for each VLAN doesn't work and will result in false connectivity tests when pinging the sub-interfaces.
On the other hand, the issue isn't about understanding whether i can put it or not, i have a suspicion that the router is faulty. It gives different outputs with the same configuration each time.
"Yet assigning
10.0.1.10
for each VLAN doesn't work and will result in false connectivity tests when pinging the sub-interfaces."
Again, what you describes implies a configuration issue most likely due to not fully understanding subinterfaces and/or VRFs.
"On the other hand, the issue isn't about understanding whether i can put it or not, i have a suspicion that the router is faulty. It gives different outputs with the same configuration each time."
Yes, router might be "faulty" but here too might your understanding be "faulty"?
An example of possible "faulty" understanding is your mention assigning
10.0.1.10
to different VLANs doesn't work.  Believe me, it can work using VRFs, assuming configuration are correct.
For a second opinion, ask @Harold Ritter as he has CCIE badges, and those with those certifications, I've found, are fairly knowledgeable.
Again, if you accept there's some possibility the different outputs you describe having are not due to a "faulty" router, we might, together, determine some other issue is the cause.
BTW, I not saying there are configuration issues on the router, itself.  We would need to analyze your overall network environment.
