Configuring Phase-3 Hierarchical DMVPN with Regional Spokes
kmcfadde
Hello Community,
I have been searching around this evening for a good DMVPN Phase-3 Hierarchical DMVPN network design that has a central hub, regional hubs, and regional spokes.  Most of the examples I found did not suit my needs so I decided to lab the configuration using GNS3 and share it with the community here.  I hope this example is helpful to others.
The importance of this example is to show how DMVPN Phase 3 shortcut paths can be dynamically established between the sites within and across the regions. I also look at route summarization to simplify the routing tables across the environment.
The diagram below is the example topology. The Central router acts as an intermediate hub between two regional hubs, Hub1 and Hub2.  Spoke1 is a spoke site within Region1 and Spoke2 is a spoke site within Region2.  The red lines show DMVPN static tunnels which connects the spokes sites to their closest hub and also interconnects the hubs.  The black lines physical connection from the DMVPN routers to a common IP cloud, emulating the Internet or a similar underlying infrastructure.
This lab example was built using IOL images running 15.6.3M3 code.
The first configuration I will explore is an environment where summarization is not configured and full routes are shared across the cloud. It is important to note that the DMVPN cloud is a single instance using the same DMVPN tunnel key and NHRP Network ID.  This is important for NHRP indirection/redirect to work properly.
The following are the tunnel configurations for the central and regional hubs.  An important item to note that is the NHRP shortcut and redirect commands. The commands help NHRP understand the functional role of the router in the DMVPN topology.  If the router is a spoke, apply the “ip nhrp shortcut” command. If the router is a hub, apply the “ip nhrp redirect” command.  If the router is both a spoke and hub, such as Hub1 and Hub2 in the example topology, then apply both commands.
Hub1
interface Tunnel0
 ip address 10.0.0.32 255.255.255.0
 no ip redirects
 ip mtu 1400
 no ip split-horizon eigrp 1    ! <- allows the hub to share routes its
                                !    learns from other hubs or spokes
 ip nhrp authentication test
 ip nhrp map multicast dynamic  ! <- allows NHRP to learn EIGRP
                                !    neighbors dynamically
 ip nhrp network-id 100000      ! <- must be the same across the cloud
                                !    for spoke-to-spoke
 ip nhrp nhs 10.0.0.1 nbma 172.17.0.1 multicast ! <- this is a static
                                                !    NHRP map to
                                                !    interconnect a
                                                !    regional hub to
                                                !    the central hub
 ip nhrp shortcut               ! <- important on spokes
 ip nhrp redirect               ! <- important on hubs
 tunnel source Ethernet0/0
 tunnel mode gre multipoint
 tunnel key 100000              ! <- must be the same across the cloud
 tunnel protection ipsec profile profile-dmvpn
Hub2
interface Tunnel0
 ip address 10.0.0.64 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp holdtime 360
 tunnel key 100000
Central
interface Tunnel0
 ip address 10.0.0.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 tunnel key 100000
The spoke tunnels configuration are similar but not the same
Spoke1
interface Tunnel0
 ip address 10.0.0.33 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp nhs 10.0.0.32 nbma 172.17.0.32 multicast
 tunnel key 100000
Spoke2
interface Tunnel0
 ip address 10.0.0.65 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp nhs 10.0.0.64 nbma 172.17.0.64 multicast
 tunnel key 100000
The result of this configuration is that all sites have visibility about the local /24 loopbacks in the network.  This is a sample of the Spoke1 routing table.
Spoke_1# show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.0.0/24 is directly connected, Tunnel0
L        10.0.0.33/32 is directly connected, Tunnel0
      172.17.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.17.0.0/24 is directly connected, Ethernet0/0
L        172.17.0.33/32 is directly connected, Ethernet0/0
D     192.168.1.0/24 [90/28288000] via 10.0.0.32, 00:00:59, Tunnel0
D     192.168.32.0/24 [90/27008000] via 10.0.0.32, 00:00:44, Tunnel0
      192.168.33.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.33.0/24 is directly connected, Loopback1
L        192.168.33.1/32 is directly connected, Loopback1
D     192.168.64.0/24 [90/29568000] via 10.0.0.32, 00:00:32, Tunnel0
D     192.168.65.0/24 [90/30848000] via 10.0.0.32, 00:00:32, Tunnel0
It is important to understand that while each site has EIGRP routes for every other site, only the DMVPN Spoke to Regional Hub and Regional Hub to Central Hub Tunnels are established.
central_hub#show dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
        N - NATed, L - Local, X - No Socket
        T1 - Route Installed, T2 - Nexthop-override
        C - CTS Capable
        # Ent --> Number of NHRP entries with same NBMA peer
        NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
        UpDn Time --> Up or Down Time for a Tunnel
Interface: Tunnel0, IPv4 NHRP Details
Type:Hub, NHRP Peers:2,
 # Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb
     1 172.17.0.32           10.0.0.32    UP 00:47:33     D <- to Spoke1
     1 172.17.0.64           10.0.0.64    UP 00:45:52     D <- to Spoke2
hub_1#show dmvpn
Type:Hub/Spoke, NHRP Peers:2,
     1 172.17.0.1             10.0.0.1    UP 00:48:41     S <- to Central Hub
     1 172.17.0.33           10.0.0.33    UP 00:40:00     D <- to Spoke1
spoke_1#show dmvpn
Type:Spoke, NHRP Peers:1,
     1 172.17.0.32           10.0.0.32    UP 00:40:16     S <- to Hub1
When spoke-to-spoke traffic occurs, the initial packets will be forwarded through the next hop hub based on the current routing table.  For example, if Spoke1 pings Spoke2, the initial routing table shows reachability for via 10.0.0.32 which is Hub1. Once NHRP resolution completes, a new next hop override is installed as shown below.
spoke_1#ping 192.168.65.1 source Loopback 1  <- from Spoke1 to Spoke2
Sending 5, 100-byte ICMP Echos to 192.168.65.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.33.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/8/12 ms
spoke_1#show dmvpn
        C - CTS Capable
Type:Spoke, NHRP Peers:2,
     1 172.17.0.32           10.0.0.32    UP 00:48:59     S
     2 172.17.0.65           10.0.0.65    UP 00:00:08   DT1 <- new dynamic
                                                               route to
                                                               Spoke2
                             10.0.0.65    UP 00:00:08   DT2 <- new dynamic
                                                               override to
                                                               Spoke2
spoke_1#show ip route
       ia - IS-IS inter area, * - candidate default, U - per-user static route
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
H        10.0.0.65/32 is directly connected, 00:00:15, Tunnel0
D     192.168.1.0/24 [90/28288000] via 10.0.0.32, 00:32:02, Tunnel0
D     192.168.32.0/24 [90/27008000] via 10.0.0.32, 00:31:47, Tunnel0
D     192.168.64.0/24 [90/29568000] via 10.0.0.32, 00:31:35, Tunnel0
D   % 192.168.65.0/24 [90/30848000] via 10.0.0.32, 00:31:35, Tunnel0
Notice the “%” indicator next to the Spoke2 route.  While the route was already in the table, a new shortcut tunnel is now present and able to carry traffic directly between Spoke1 and Spoke2.
Spoke2 shows a similar status even though the traffic originated from Spoke1.  The output below shows a new dynamic tunnel and next hop override established from Spoke2 to Spoke1.
spoke_2#show dmvpn
        C - CTS Capable
     2 172.17.0.33           10.0.0.33    UP 00:04:14   DT1
                             10.0.0.33    UP 00:04:14   DT2
     1 172.17.0.64           10.0.0.64    UP 00:51:48     S
spoke_2#show ip route
H        10.0.0.33/32 is directly connected, 00:04:20, Tunnel0
L        10.0.0.65/32 is directly connected, Tunnel0
L        172.17.0.65/32 is directly connected, Ethernet0/0
D     192.168.1.0/24 [90/28288000] via 10.0.0.64, 00:36:07, Tunnel0
D     192.168.32.0/24 [90/29568000] via 10.0.0.64, 00:35:52, Tunnel0
D   % 192.168.33.0/24 [90/30848000] via 10.0.0.64, 00:35:52, Tunnel0
D     192.168.64.0/24 [90/27008000] via 10.0.0.64, 00:35:40, Tunnel0
      192.168.65.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.65.0/24 is directly connected, Loopback1
L        192.168.65.1/32 is directly connected, Loopback1
It is important to note that no new EIGRP neighbors were formed as a result of the spoke-to-spoke tunnel establishment.
spoke_1#show ip eigrp neighbors
EIGRP-IPv4 Neighbors for AS(1)
H   Address          Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   10.0.0.32        Tu0                      14 00:55:11   27  1362  0  19
spoke_2#show ip eigrp neighbors
                                                   (sec)         (ms)       Cnt Num
0   10.0.0.64        Tu0                      14 00:54:04   20  1362  0  55
As the number of sites in a region increases, the routing table size and complexity will increase. To help control this issue route summarization can be implemented at the central and regional hubs.  In this case the 192.168.0.0 can be nicely grouped into a enterprise summary route at the Central router with prefix 192.168.0.0/16 and regional summary routes at each of the hubs with 192.168.32.0/19 and 192.168.64.0/19. The important aspect of this example to consider is that the regional summary routes do not overlap or cause ambiguity.  In this configuration, an overlapping summary can cause traffic to be black holed.
The following output shows the summary configurations applied to the hub tunnel interfaces.
central_hub#show run interface tunnel 0 | include ^interface|summary
interface Tunnel0
 ip summary-address eigrp 1 192.168.0.0 255.255.0.0
hub_1#show run interface tunnel 0 | include ^interface|summary
interface Tunnel0
 ip summary-address eigrp 1 192.168.32.0 255.255.224.0
hub_2#show run interface tunnel 0 | include ^interface|summary
interface Tunnel0
 ip summary-address eigrp 1 192.168.64.0 255.255.224.0
The following output shows the Spoke1 routing table and DMVPN tunnel status before any spoke-to-spoke traffic occurs. Notice that all of the 192.168.x.0/24 routes from the other sites have been replaced by two prefixes, the 192.168.0.0/16 enterprise and 192.168.32.0/19 regional summaries.
D     192.168.0.0/16 [90/28288000] via 10.0.0.32, 00:13:33, Tunnel0
D     192.168.32.0/19 [90/27008000] via 10.0.0.32, 00:21:11, Tunnel0
spoke_1#show dmvpn
     1 172.17.0.32           10.0.0.32    UP 01:25:27     S
                                                   (sec)         (ms)       Cnt Num
0   10.0.0.32        Tu0                      12 01:25:33   31  1362  0  31
When spoke-to-spoke demand traffic occurs, the initial traffic is carried via the summary routes through the hubs.  In parallel, an NHRP resolution is found and a dynamic tunnel is formed.  The output below shows the new route installed in the routing table and the new tunnel relationship.  The output also shows that no new EIGRP neighbors occur during this process.
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/6/11 ms
spoke_1#sh dmvpn
        C - CTS Capable
     1 172.17.0.32           10.0.0.32    UP 01:37:05     S
     2 172.17.0.65           10.0.0.65    UP 00:00:05   DT1 <- new NHRP route
                                                               installed
H        10.0.0.65/32 is directly connected, 00:00:13, Tunnel0
D     192.168.0.0/16 [90/28288000] via 10.0.0.32, 00:25:28, Tunnel0
D     192.168.32.0/19 [90/27008000] via 10.0.0.32, 00:33:06, Tunnel0
H     192.168.65.0/24 [250/255] via 10.0.0.65, 00:00:13, Tunnel0
                                                   (sec)         (ms)       Cnt Num
0   10.0.0.32        Tu0                      14 01:37:34   31  1362  0  31
spoke_2#show dmvpn
        C - CTS Capable
     2 172.17.0.33           10.0.0.33    UP 00:00:20   DT1 <- new NHRP route
                                                               installed
     1 172.17.0.64           10.0.0.64    UP 01:36:03     S
H        10.0.0.33/32 is directly connected, 00:00:27, Tunnel0
D     192.168.0.0/16 [90/28288000] via 10.0.0.64, 00:25:41, Tunnel0
H     192.168.33.0/24 [250/255] via 10.0.0.33, 00:00:27, Tunnel0
D     192.168.64.0/19 [90/27008000] via 10.0.0.64, 00:32:21, Tunnel0
The full router configurations are shown below for your convenience
hostname central_hub
ip cef
crypto isakmp policy 1
 encr aes 256
 hash sha256
 authentication pre-share
 group 2
crypto isakmp key cisco123 address 0.0.0.0
crypto ipsec transform-set transform-dmvpn esp-aes 256 esp-sha-hmac
crypto ipsec profile profile-dmvpn
 set transform-set transform-dmvpn
interface Loopback1
interface Tunnel0
 no ip redirects
 ip mtu 1400
 ip nhrp redirect
 tunnel key 100000
interface Tunnel1
 no ip address
interface Ethernet0/0
 ip address 172.17.0.1 255.255.255.0
router eigrp 1
 network 10.0.0.0
 network 192.168.0.0 0.0.255.255
end
hostname hub_1
ip cef
 encr aes 256
 hash sha256
 group 2
interface Loopback1
 ip address 192.168.32.1 255.255.255.0
interface Tunnel0
 no ip redirects
 ip mtu 1400
 ip nhrp shortcut
 ip nhrp redirect
 tunnel key 100000
 ip address 172.17.0.32 255.255.255.0
router eigrp 1
 network 10.0.0.0
end
hostname hub_2
ip cef
 encr aes 256
 hash sha256
 group 2
interface Loopback1
 ip address 192.168.64.1 255.255.255.0
interface Tunnel0
 no ip redirects
 ip mtu 1400
 ip nhrp shortcut
 ip nhrp redirect
 tunnel key 100000
 ip address 172.17.0.64 255.255.255.0
router eigrp 1
 network 10.0.0.0
end
hostname spoke_1
ip cef
 encr aes 256
 hash sha256
 group 2
crypto isakmp keepalive 10
interface Loopback1
 ip address 192.168.33.1 255.255.255.0
interface Tunnel0
 no ip redirects
 ip mtu 1400
 ip nhrp shortcut
 tunnel key 100000
 ip address 172.17.0.33 255.255.255.0
router eigrp 1
 network 10.0.0.0
end
hostname spoke_2
ip cef
 encr aes 256
 hash sha256
 group 2
interface Loopback1
 ip address 192.168.65.1 255.255.255.0
interface Tunnel0
 no ip redirects
 ip mtu 1400
 ip nhrp shortcut
 tunnel key 100000
 ip address 172.17.0.65 255.255.255.0
router eigrp 1
 network 10.0.0.0
end
hostname Internet
ip cef
bridge irb
 no ip address
 bridge-group 1
interface Ethernet0/1
 no ip address
 bridge-group 1
interface Ethernet0/2
 no ip address
 bridge-group 1
interface Ethernet0/3
 no ip address
 bridge-group 1
interface Ethernet1/0
 no ip address
 bridge-group 1
bridge 1 protocol ieee
end
Hi kmcfadde,
I have realized the same lab on GNS3 (with IOSv Routers), but unable to have 172.17.0.33 as a peer on spoke 2 & 172.17.0.65 on spoke 1. Please help in identifying the issue. Configuration files are attached.
Hello Kmcfadde
nice review to phase3 dmvpn
kudos
Kind Regards
Paul
