Configuring ppp with chap authent.
Reprovoid
Hi.I've configured ppp on two routers In a home lab.I've enabled chap authentication with the ppp authentication chap command.The connections are up and working.The problem Is It doesnt matter what username and password combination I use on the routers.It still works.From what I've read I have to use the hostname of the peer as a username and Identical passwords.What might I be doing wrong here ?
just do a shut/no shut of your serial interface and you will see it is not working.
you can do  debug ppp authentication to see what is the problem.
Regards.
Alain
10 Replies 10
cadet alain
take a look here:http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a00800b4131.shtml
Regards.
Alain
johnlloyd_13
Level 9
Level 9
hi,
i recently read CCNA CNAP's chapter 2 - PPP and here's what i got from my notes and sample below. the hostname on one router must match the username the other router has configured. the passwords must also match. this occurs on initial link establishment and can be repeated any time after the link has been established
hostname R1
username R3 password 0 someone
interface Serial0/1/0
ip address 172.16.0.1 255.255.255.252
encapsulation ppp
clock rate 64000
Serial0/1/0 IPCP: I CONFREQ [Closed] id 1 len 10
Serial0/1/0 IPCP: O CONFACK [Closed] id 1 len 10
Serial0/1/0 IPCP: I CONFREQ [REQsent] id 1 len 10
Serial0/1/0 IPCP: O CONFACK [REQsent] id 1 len 10
Serial0/1/0 IPCP: O CONFREQ [Closed] id 1 len 10
Serial0/1/0 IPCP: I CONFACK [Closed] id 1 len 10
Serial0/1/0 IPCP: I CONFACK [REQsent] id 1 len 10
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to up
hostname R3
username R1 password 0 someone
interface Serial0/0/0
ip address 172.16.0.2 255.255.255.0
encapsulation ppp
Thats what I've read too.But It's still working whatever password , username config I use.I'm doing something wrong.
Peter Paluch
In addition to the recommendations of John and Alain, would you mind posting your configurations of both routers?
Best regards,
Peter
I've attached the startup config both routers.My problem Is It still works even with different passwords and usernames.
Regards.
Alain
Thanks.I'm happy to report things have stopped working!
hi,
i tried to simulate your config and it's not working. when re-configured the username to match the remote router and using same passwords, the serial links went up. could you try it on your lab and confirm?
hostname R1.12
username R1.12 password 0 reprovo
interface Serial0/0
ip address 192.168.6.3 255.255.255.0
encapsulation ppp
clock rate 128000
hostname R2.10
username R2.10 password 0 rep
interface Serial0/0
ip address 192.168.6.1 255.255.255.0
encapsulation ppp
R1.12#sh ip int br
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        unassigned      YES unset  administratively down down
Serial0/0              192.168.6.3     YES manual up                    down
R2.10#sh ip int br
Serial0/0              192.168.6.1     YES manual up                    down
R1.12(config)#username R2.10 password reprovo
R1.12(config)#
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state to up
R2.10(config)#username R1.12 password reprovo
R2.10(config)#
Yeah as cadet Alain pointed out I had to shutdown no shutdown on the serial Interfaces.The connection then stopped working
ok great!
