configuring pppoe in cisco CLI (VPDN or bba-group)???
arun kumar
Hi All,
My scenario is like below:
Cisco 1841 or 2811 router -- DSL modem --- Aggregation router.
Cisco 1841 or 2811 should initiate a PPPOE to the Aggregation router.
When I started configuring PPPoE, i am not able to find the "protocol pppoe" option under vpdn group. (though on Cisco's FN pppoe-client support is listed on the IOS)
LAB-CE2-1841(config)#vpdn-group 1
LAB-CE2-1841(config-vpdn)#pro
LAB-CE2-1841(config-vpdn)#pro?
% Unrecognized command
LAB-CE2-1841(config-vpdn)#reque
LAB-CE2-1841(config-vpdn)#request-diali
LAB-CE2-1841(config-vpdn)#request-dialin
LAB-CE2-1841(config-vpdn-req-in)#pro
LAB-CE2-1841(config-vpdn-req-in)#protocol ?
l2f Use L2F
l2tp Use L2TP
This above router should initiate a PPPoE to the Aggregation router.
Just came across about the "bba-group pppoe" config CLI. Would like to know currently PPPoE under VPDN is replaced with bba-group CLI.
Or bba-group CLI should only be used on the aggregator side.
Any help is much appreciated.
thanks
Arun Kumar
Giuseppe Larosa
Hello Arun,
there was a change and newer IOS versions simply don't need to configure VPDN to support PPPoE client
you need just to configure under fe port
int fe0/0
pppoe-client dial-pool-number 1
int dialer
interface Dialer1
ip address negotiated
ip mtu 1492
bba-group is needed if you want to use more then one PPPoE session
Hope to help
Giuseppe
Giuseppe Larosa
Hello Arun,
int fe0/0
int dialer
interface Dialer1
ip mtu 1492
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your valuable help. It is working.
thanks
Arun Kumar
Do you need to use
pppoe enable group global
