Configuring PPPoE with FVRF on a C881
lap
Level 2
Level 2
I have a big doubt on how I can configure PPPoE on a C881 with FVRF. I explain a bit deeper. Our customer is migrating from a IPsec HUB and SPOKE network to a DMVPN network. There is a SPOKE location in France which should get a new C881 to join the DMVPN network. My problem is that the ISP in France is using PPPoE and I have VRF configured on the Internet facing interface.
If I tried the following the ip address negociated in not taken in account:
interface FastEthernet 4
description ***Connection to WAN***$ETH-WAN$
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no shutdown
interface Dialer0
bandwidth 670
ip access-group OUTSIDE_IN in
ip vrf forwarding FVRF
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp pap sent-username X password 0 X
So if I try to add ip address negociated to interface dialer 1 the command is not taken in account!
Does anyone knows how I can solve this problem? Maybe with virtal-interface? Does the PPPoE config looks ok?
Laurent
lap
Level 2
Level 2
So I found out how to solve this issue.
You have to do the following:
default interface dialer 0 //if dialer 0 was alredy configured
interface dialer 0
ip vrf forwarding X
shutdown
Then you should add the rest of the PPPoE config to the dialer interface:
interface Dialer0
encapsulation ppp
dialer pool 1
ppp chap hostname fti/fdguhk3
ppp chap password 0 gkccp9ca
ppp ipcp route default
Laurent
