Configuring QoS on ATM Sub-Interfaces
navneet_78
I have a policy map defined on a 3845 router running c3845-advipservicesk9-mz.124-3b.bin.
Iam trying to configure the service policy under the PVC, but it does not reflect in the running config.
PLease find the ATM PVC config below.
interface ATM1/0.130 point-to-point
ip x.x.x.x
ip access-group sqlfix out
ip wccp web-cache redirect out
ip wccp 80 redirect out
ip wccp 81 redirect out
ip wccp 82 redirect out
ip wccp 83 redirect out
ip pim sparse-dense-mode
ip multicast boundary multicast_boundary_medbw
ip multicast rate-limit out 1024
ip mrm test-receiver
ip summary-address eigrp 100 x.x.x.x
pvc abcd 2/130
vbr-nrt 1920 1920 1
max-reserved-bandwidth 100
Appreciate your help.
Navneet
Joseph W. Doherty
Does you policy use absolute bandwidth values? Does the policy's total bandwidth exceed the interface's bandwidth? If so, I've seen IOS quietly drop the policy at the command line. (Belive it syslogs it, though.)
If your are using absolute bandwidth values in your policy, trying using percentage based bandwidth values.
Thanks for your Reply Joseph!!
I have shaping parameter defined under my class maps. Does that create an issue?
class video-bearer
bandwidth percent 1
shape average percent 1
class medium-priority
bandwidth percent 40
shape average percent 40
Navneet
Shapers throttle traffic; setting a maximum bandwidth allowance. The bandwidth statement sets a minimum allowance, except for LLQ where it also is a rate limiter. If this is what you intend, shouldn't be an issue.
PS:
Normally, you allow classes to use excess bandwidth.
