Configuring "PBR Support for Multiple Tracking Options" on Cat3550
s.cimmino
I'm trying to configure the "PBR Support for Multiple Tracking Options" feature on a Cat3550 with 2.2(25)SEB4 IOS software. I'm following the example in document ID: 48003, but my switch does not accept the command "verify-availability" while configuring the "ip next-hop".
Is there any alternative command that I should use according to my IOS version?
I also tried to configure the same feature on a 2600 router with 12.4(4)T IOS, using the "ip sla" command instead of "rtr", but I haven't find the right commands. Have you got any example that can be a help to me?
Thanks.
I've attached a document. Have a look at it, might help.
AbhisheK
Please rate all posts!!!
Thank you AbhisheK for you replay,
I had already seen that document, but I had to stop at step 7, because the router does not accept the line "track 123 rtr 1 reachability".
"rtr" is not an allowed command after "track xxx", but I can't find an alternative valid command.
Silvia
Silvia,
To choose the correct IOS which supports, rtr, tracking and PBR you can use IOS feature navigator. Below is the url:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Choose select by feature and add all the required features you want
I did it,
the IOS 12.2(25)SEB4, feature set IP Service (which I have), supports PBR, IP SLA and RTR, but it doesn't accept the command "set ip next-hop verify-availability A.B.C.D track xxx" written in the example document.
