Configuring reflexive ACLs on IOS XE
stephenbowman1
I have been trying to move a configuration to a new ASR1002x. The old config uses reflexive ACLs but the ASR errors out on the configuration. The documentation I have seen indicates there should be no problem. Am I missing something.
Ruben Cocheno
give a look here https://supportforums.cisco.com/discussion/11250391/asr1001-ios-xe-320s-reflexive-access-lists
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
swj
I knew this is old post, however i was just came across same situation today on, one of the Customer Router upgrade.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn75709/?reffering_site=dumpcr
There is a ENH for the same. Alternative approach is ZBF/CBAC
Hope this helps for some-other :)
