Configuring RIP (Empty RIP Database)
Hello everyone, while configuring RIP in VRF, I encountered a problem where RIP is configured, but it's not showing in the database (completely empty).
Here's my configuration:
router rip
version 2
network 192.168.1.0
address-family ipv4 vrf red
redistribute connected
network 192.168.1.0
neighbor 192.168.1.12
no auto-summary
exit-address-family
address-family ipv4 vrf blue
network 192.168.1.0
neighbor 192.168.1.13
no auto-summary
exit-address-family
Any help would be much appreciated.
12 Replies 12
I need to see all config
Current configuration : 2892 bytes
! Last configuration change at 08:42:24 UTC Fri Jun 30 2023
version 15.0
hostname myrouter
boot-start-marker
boot-end-marker
enable secret 5 $1$AMYY$sEXFgKu.yngef7hiP8Dgu1
enable password cisco123
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip vrf blue
rd 65000:2
ip vrf red
rd 65000:1
license udi pid CISCO1921/K9 sn FCZ1434C389
interface Loopback1
ip vrf forwarding red
ip address 10.0.0.1 255.255.255.255
interface Loopback2
ip vrf forwarding blue
ip address 10.0.0.2 255.255.255.255
interface Loopback10
ip address 128.0.0.1 255.255.0.0
interface GigabitEthernet0/0
bandwidth 100
ip address 192.168.1.12 255.255.255.0
ip ospf network point-to-point
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description unused available port
ip address 192.168.1.13 255.255.255.0
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
router ospf 2 vrf blue
router-id 10.0.0.2
log-adjacency-changes
redistribute static subnets
network 192.168.1.0 0.0.0.255 area 0
router ospf 1 vrf red
router-id 10.0.0.1
router rip
version 2
network 192.168.1.0
network 192.168.1.0
no auto-summary
exit-address-family
network 192.168.1.0
no auto-summary
exit-address-family
router bgp 65000
no synchronization
no bgp log-neighbor-changes
no auto-summary
no synchronization
bgp router-id 192.168.1.12
network 10.2.0.0 mask 255.255.255.0
neighbor 192.168.1.13 remote-as 65000
neighbor 192.168.1.13 activate
exit-address-family
no synchronization
bgp router-id 192.168.1.13
network 10.1.0.0 mask 255.255.255.0
neighbor 192.168.1.12 remote-as 65000
neighbor 192.168.1.12 activate
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf blue 10.2.0.0 255.255.255.0 Null0
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
password cisco
line aux 0
password cisco
login
modem InOut
transport input all
speed 115200
flowcontrol hardware
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
scheduler allocate 20000 1000
end
Hello @Cisco Enthusiast,
The "neighbor" statements under the address families are incorrect. The neighbors specified should be the IP addresses of the routers to which the RIP updates should be sent. It seems that you have used the interface IP addresses instead of the neighboring router IP addresses.
You want hairpinning config ?
it seems to be that! Then use the "redistribute rip" command within each VRF's address family configuration. It will redistribute RIP routes into each VRF, allowing the hairpinning of RIP updates between the VRFs. Make sure that you have configured the appropriate VRF routing instances and interfaces for proper communication between the VRFs.
router rip
 version 2
 network 192.168.1.0
 redistribute rip
 no auto-summary
 exit-address-family
 redistribute rip
 no auto-summary
 exit-address-family
Best regards
myrouter(config-router-af)#redistribute rip
redistribution of "rip" via "rip" not allowed
your config is correct you redistribute connected (loopback) which config with vrf aware
so
try the following
show ip rip vrf RED/BLUE database
myrouter#show ip rip vrf blue database
% Invalid input detected at '^' marker.
 If you run show ip route vrf XX rip ?
When i type : show ip route vrf xx rip
the route is there but when i type :show ip rip database
it's empty ,it's like there is no configuration .
And   you have more then one Router and they have similar configuration? Can I see the second router config ?
Actually it's one router and two vrfs as shown above in full configuration.
Right.
 How are you using the command  show ip rip vrf <XX> ?
it's not :show ip rip vrf xx
but:
show ip router vrf blue rip
show ip route vrf red rip
