Configuring Route map in Switch WS-C3750X-24
mhuaynate
Hi Firends,
I want to kown if is posibble to configurate route map in sw-c3750x-24 or only is for router?
I made this configuration:
ip access-list extended TDP
permit ip host 192.168.1.79 any
ip access-list extended Claro
permit ip 192.168.1.0 0.0.0.255 any
route-map INTERNET permit 10
match ip address TDP
set ip next-hop 192.168.5.253
route-map INTERNET permit 20
match ip address Claro
set ip next-hop 192.168.5.254
interface vlan
ip policy route-map INTERNET               +++ There is not this command in my switch
My ios version is c3750e-universalk9-mz.122-55.SE  ipbase.
Thank,
Marco.
nickhesson
Hi Marco,
Your best bet is to search Cisco Feature Navigator for these types of questions. But ipbase does not support Policy-Based Routing (PBR).  I believe IP services does.
Nick
HI nickhesson,
but is posibble to configurate it in switch L3. ? do you kown ?
Thank,
Marco.
Short answer, yes.  But not with your current (ipbase) feature set.  You will need IP Services.  Again, you can find this information on the Feature Nav site.
Nick
Here is the IOS you can use -
c3750-ipservicesk9-mz.150-1.SE2.bin
Thank you,
Jigar
