CONFIGURING SITE TO SITE IPSEC VPN BETWEEN TWO OFFICES
tomocisco
Hi All,
Thanks for a forum like this that has continued to help individuals like me in my career as a network administrator.
I am presently configuring a VPN connection between two of our offices so that we can have data/voice/video connectivity between the two sites. We want users to be able to access internet, while the vpn tunnel will be mainly for data/voice/video connectivity.
I am using Cisco 1812 for this configuration.
Attached is a 'show running configuration' from the local Router. My questions are:
1. Will the configuration shown give me the desired vpn connection as well as give users access to internet?
2. Is there a way to delegate bandwith (say 2mbps) just for internet use while the rest of the bandwidth will be for vpn data traffic?
The 'sho run' is pasted below
Router#sho run
Building configuration...
Current configuration : 2179 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$UOub$z7fLtnBI.El8lsWrFr6v/0
enable password 7 130816011F091639
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
ip name-server 41.198.x.y
ip name-server 41.198.x.z
crypto isakmp policy 1
encr aes 256
hash md5
authentication pre-share
group 2
crypto isakmp key SeCRetKey address 41.200.t.y (PUBLIC IP ADDRESS OF REMOTE ROUTER FROM ISP)
crypto ipsec transform-set MY-VPN esp-aes 256 esp-md5-hmac
crypto map VPN-LG 10 ipsec-isakmp
set peer 192.168.1.1
set transform-set MY-VPN
match address VPN-TRAFFIC
archive
log config
  hidekeys
interface Loopback0
ip address 192.100.100.1 255.255.255.255
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address 41.198.X.Y 255.255.255.248 (PUBLIC IP ADDRESS OF LOCAL ROUTER FROM ISP)
ip nat outside
duplex auto
speed auto
crypto map VPN-LG
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 41.198.T.K (DEFAULT GATEWAY OF ISP)
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet1 overload (NAT FOR INTERNET ACCESS)
ip access-list extended VPN-TRAFFIC
permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 remark EXCLUDED FROM NAT
access-list 100 deny   ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
control-plane
line con 0
password 7 00091215105E1915
login
line aux 0
line vty 0 4
password 7 082C4D5D1D1C1704
login
line vty 5 193
login
end
Thanks for your help.
Tom
17 Replies 17
Hi Giuseppe,
Thanks once more for your precious time.
Referring to the your post above where you said
I would check if these servers have two default gateways configured and  they are load balancing over them, with one being the correct gateway  and one being a device that is not able to route over the VPN."
Only one default gateway is configured on all the systems. What more do you think could be responsible for this kind of behavior?
As to what I did to bring up the VPN tunnel. I found out that I had a static NAT statement point to a particular system that needed to be accessed from the internet, once I removed that NAT statement, my VPN came up. I will still return to it later when I am through with the Vpn configuration.
Thanks for your inputs, you helped me a lot. (Of course I'll rate you at d end of this configuration bcos i'm sure success is just by the corner). Thanks
Tom
Hello Tom,
mine was just a suggestion of a possible cause. It is not clearly the case.
I wonder if there are other static NAT statements that may cause problems.
However, I would suggest also to try to perform tests from a different system just to check if the behaviour changes.
What if you use extended ping on the router of one site with source address = internal LAN address  and you try to ping systems on the remote internal Vlan?
Are the results the same?
You told in a previous post that a specific end system on the remote site is pingable, is it still true?
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your time in responding to my posts.
Any idea on how to resolve the issue above? VPN is up but having issues reaching resources in LAN. Ping to router LAN interfaces replies without breaking but ping to systems breaks.
