Configuring SSL VPN in Cisco Packet Tracer
chrxmvtik
I just wanted to ask if there a possibility to configure SSL VPN in Cisco Packet Tracer on such a routers like 1841, 2811 or 2620 or if there is a possibility at all. Tried to configure it somehow, but some commands are not avaliable. Cheers
to be sure I rechecked all IOS routers in the latest version of Packet Tracer...SSL VPN is not supported on any of them, only IPSec VPN is...
balaji.bandi
I have not used anytime packet tracer(never required for me simulators)
but i see some option here if you like to test :
https://www.packettracernetwork.com/labs/lab16-asa-webvpn.html
BB
Thanks, sadly I can only you routers that I specified above :(
Hi! Thanks for reply, I have also checked old and new versions of CPT including various firmware versions on routers and seems like you are right. At least there is a possibility to configure IPsec VPN tho..
Cheers
