Configuring WCCP
damrut5763
I am trying to configure WCCP on my 6513 switch and use my management VLAN as the interface with that particular IP address as the WCCP router IP address(i.e IP Unnumbered) however I am getting his error:
DP6513(config)#int lo255
DP6513(config-if)#ip unnu
DP6513(config-if)#ip unnumbered vlan 1
Point-to-point (non-multi-access) interfaces only
I am running 12.2(18)SXF3
Please Help!!!!!
" remember that the ip unnumbered command works on point-to-point interfaces only. When you configure the command on the Multiaccess interface (that is, Ethernet) or the loopback interface, the following messages are displayed:
RouterA(config)# int e0
RouterA(config-if)# ip unnumbered serial 0
RouterA(config-if)# ip unnumbered loopback 0
Point-to-point (non-multi-access) interfaces only "
Reference http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8d.shtml
I hope this helps.
Best regards.
Massimiliano.
Thanks!!!!!
Jon Marshall
The error message says it all really. You can only use "ip unnumbered" on a point-to-point interface and both ethernet and the loopback are counted as multi-access. See attached link for more details
Jon
