Confirm my understanding of 'ospf passive-interface'
news2010a
Level 3
Level 3
Hey, I understand that the command
passive-interface
will prevent routing updates from being sent on the respective interface (in this case, vlan100).
That means that the network advertised below (11.172.101.128) will be advertised, but only the vlan100 will not send routing updates about it, correct?
interface Vlan100
ip address 11.172.101.130 255.255.255.128
no clns route-cache
no shutdown
interface Port-channel1
switchport trunk allowed vlan add 100
router ospf 300
passive-interface Vlan100
network 11.172.101.128 0.0.0.127 area 0.0.0.117
lamav
Level 8
Level 8
The
passive-interface
command behaves differently, depending on the protocol being used.
In RIP this command will disable sending updates via a specific interface but will allow listening to incoming updates from other RIP speaking neighbors.
In EIGRP it prevents any Hellos from being sent, and therefore does not allow a neighborship to be established, nor any routes to be learned through that interface.
In OSPF, the
passive interface
command does the same as in eigrp. It prevents Hellos from being sent and thereby disallows adjacencies from being formed. And if an adjacency does exist and the command is executed, the adjacency will be disolved.
However, the
passive-interface
command does not prevent LSAs from being passed. This is why OSPF neighbors hanging off of different interfaces on that router will learn of that passive interface's network address. LSAs will still be placed in the local OSPF database and then sent and sourced by that interface. This is true, of course, if you are advertising the network under the OSPF process (ie, running OSPF on that interface). In that case, you should see a type 1 router LSA in the OSPF database for that network.
Your other option would be to redistribute connected, which will be advertised as a type-5 extrenal LSA.
Victor
7 Replies 7
royalblues
Level 10
Level 10
Passive interface
just stops sending OSPF hellos out of their interface and hence you will not be able to make any adjacencies via that interface
This command is useful as there is no need to send ospf hellos if there is no neighbor available at the other end
In your case the subnet is still advertised via OSPF but no OSPF hellos are sent out (you can verify it via debug commands)
Narayan
Jon Marshall
Marlon
Not strictly correct. Making the interface passive will stop an adjacency being formed with other OSPF routers on that subnet - vlan 100. So that this router will not send advertisements on vlan 100.
However the
under the router ospf 300 config does not tell this router to advertise the 11.172.101.128 network. It tells the router to start OSPF running on any interface on this router that falls within the 11.172.101.129 - 254 range. The network statement behaves the same way for EIGRP/RIP.
As an additional point, with BGP a
network x.x.x.x mask x.x.x.x
under the BGP config does actually tell the router to advertise that network.
Jon
lamav
Level 8
Level 8
The
passive-interface
In OSPF, the
passive interface
However, the
passive-interface
Victor
You guys rule. Thanks!
Thanks for the rating.
Anytime...
Victor
Well if it's not sending hellos, it forms no neighborships and thus can't advertise any routes, in addition to not learning any.
What, then, is the point of having that interface under EIGRP at all?
As Victor mentioned in his post, you would require this network to be configured so that it can be advertised to other eigrp neighbors on a different interface or else you would need redistribute connected under EIGRP
Narayan
